| Home > General Chat > piston rings seem to be the problem with the hog | |||||||
8th Dec, 2007 at 02:09:56pm
well after fitting the new set of mega pistons after the last cafuffle she has done 200 miles and guess what the smoking has came back on a fastish down run eg 3500 rpm to 2500 the put the acclerater down and the smoke would come out of the exhaust not lots but enough but would only do this when oil is hot eg over 70 deg.
8th Dec, 2007 at 03:33:05pm
Hogster, 0.040" too big on the gap is equivalent to 0.011" too much on the bore, looks like the oil rings are very worn or were 0.010 undersize to the bore to begin with.
8th Dec, 2007 at 03:40:34pm
my sentiments dave seem to big to start with bore isnt 11thou to big that i know as i have just measrued bottom skirt to bore clearance and is 2 thou at the back of the skirt so seem fine on bore size.
8th Dec, 2007 at 03:41:11pm
oh and the first set had done 1000 miles and second only 200 miles always looking for them bigger bunches of bannanas |
8th Dec, 2007 at 03:54:02pm
Measure the piston across the pins just below the scraper ring, then measure the bore. If the difference is bigger than the piston clearance, the bore is too big. On 26th Oct, 2004 TurboDave16v said:
8th Dec, 2007 at 04:24:16pm
This still relevent? though I wouldn't think so as the pistons were bought nearly 5 years ago, but mabie a similar problem has arisen at the suppy end.
Edited by minimole23 on 8th Dec, 2007. On 7th Oct, 2010 5haneJ said:
8th Dec, 2007 at 04:33:39pm
sounds like minimole but we are talking 8 pistons worth here so thats some cock up always looking for them bigger bunches of bannanas |
![]() 508 Posts Member #: 487 Post Whore westbury, wiltshire |
8th Dec, 2007 at 05:35:15pm
this sounds exactly like what happened to me, my rings were 20 undersized, on start up it would smoke for thirty seconds and then stop, i would only be able to see smoke when i was on over run and then when i put my foot down a little puff would come out of the exhaust, took it all apart and sure enought rings were for 20 oversize bore and i had a 40 oversize bore, guess what big ring gaps same as you "Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
8th Dec, 2007 at 05:49:37pm
If it is indeed the wrong ring size, then yes the ring tension is too light.
8th Dec, 2007 at 06:23:16pm
Has it bored slightly on the piss perhaps? Even a good machinist has the odd cockup. Only guessing...but something is amiss.
On 19th Jan, 2010 wil_h said:
8th Dec, 2007 at 07:50:20pm
is there an alternative ? total seal rings?
8th Dec, 2007 at 08:06:29pm
well reading the mini columns, old calver is liking his total seal rings...
8th Dec, 2007 at 08:40:39pm
Not had a problem with my 74mm total seal rings, I rate them.
