| Home > Help Needed / General Tech Chat > CARB SPACER FOR A HIF44. | |||||||
![]() 862 Posts Member #: 1660 Formally Mini_Uk London |
8th Dec, 2007 at 02:33:47pm
Is this the right spacer i need for the carb ?
Shit Happen's |
8th Dec, 2007 at 03:34:10pm
Burlen's a good call for carb spacer
Edited by Jason G on 8th Dec, 2007. On 19th Jan, 2010 wil_h said:
9th Dec, 2007 at 12:22:11am
Can some tell me if it's the Insulating Gasket 6mm thick Phenolic H6/HD6/HS6/HIF 1.75" Diameter one i need..
Shit Happen's |
444 Posts Member #: 2885 Senior Member |
26th Feb, 2009 at 11:15:03pm
Excavated this one because I have an inlet manifold and a spacer and a throttle cable plate and a carb but when all are sandwiched together, the progressive butterfly spindle arm still fould the inlet manifold..
26th Feb, 2009 at 11:23:49pm
Edited by Bat on 26th Feb, 2009. VEMs Authorised Installer / Re-seller. K head kits now available!
26th Feb, 2009 at 11:32:40pm
Plate next to carb but the problem is there arent enough things to sit the carb far enough away from the manifold, so order does not affect my predicament? It is a converted NA carb. any chance they have an incorrectly shaped throttle arm thing? |
27th Feb, 2009 at 04:24:31am
Mine also fouled on first installation,but I am a born bodger so I "eased" the manifold a little and got about 10 thou clearance, which is enough, isn,t it ?. |
27th Feb, 2009 at 07:46:11am
Yes, I used a Montego carb and the progressive spindle fouled the manifold with all the spacers in the right place.
27th Feb, 2009 at 07:08:34pm
A free solution, excellent!
