| Home > Help Needed / General Tech Chat > hardrive data recovery. | |||||||
8th Dec, 2007 at 08:46:16pm
right chaps, my hard drive has gone bad, the man in the shop [ who i trust at his word] says its completely fooked and he cannot run it to recover anything, all my stuff is on this HD, he says theres an outside chance i could have the HD rebuilt and try to recover what i can,
8th Dec, 2007 at 09:42:53pm
If you have a new machine you can put it in a caddy and try Lost and found...
8th Dec, 2007 at 09:50:35pm
Edited by Bat on 8th Dec, 2007. VEMs Authorised Installer / Re-seller. K head kits now available!
8th Dec, 2007 at 11:37:57pm
I have a very good friend that does that sort of thing carl ill give him a bell for you and hes only in casleford aswell ?
524 Posts Member #: 1380 Post Whore Swindon |
8th Dec, 2007 at 11:54:13pm
you can get a windows xp cd that will boot up directly from the cd eliminating booting up from the hdd. although it runs slow, its perfect for starting up windows, copying the data you need across to another pc that is networked to it, or a secondary hdd / removable one.
neil_g, with all due respect, your the worse salesman on TM since rob_h tried to sell his own ass |
8th Dec, 2007 at 11:57:52pm
Data recovery from broken drives is very expensive. Rebuilding the drive has a very low sucess rate.
In the 13's at last!.. Just |
567 Posts Member #: 102 Post Whore Pennsylvania USA |
9th Dec, 2007 at 12:17:31am
If it wont spin up get it cold then try it again. |
9th Dec, 2007 at 11:00:58am
i had this prob a few years ago carl, in the hd theres a wiper arm that travels across the disc and picks up data , bit like an old gramaphone player , if it stops working the hd can make a click click click noise ,this is when i took off the side of the hd ,and tried to repair it by putting the arm from another hd in with its motor ,unfortunately i couldnt get the nut holding the arm undone and that was where i stopped . if you have a go then the main thing is to keep it all totally dust free . Edited by robert on 9th Dec, 2007. Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
9th Dec, 2007 at 11:17:35am
On 9th of Dec, 2007 at 11:00am robert said:
the main thing is to keep it all totally dust free . That's why they are constucted in a controlled enviroment. The slightest bit of dust will corrupt the data. If the information is very important to you you then get it done properly. In the 13's at last!.. Just |
9th Dec, 2007 at 06:02:06pm
Connect it to your new tower. Set the jumper on the back of the hard drive to slave if you new one runs a IDE hard drive. If its SATA, theres no jumpers. Try and copy the data.....if it spins up of coarse On 19th Jan, 2010 wil_h said:
9th Dec, 2007 at 06:32:20pm
turn on teh shower in your bathroom reall hot, let it run till it is very steamy. turn it off, when the steam(well, techinically water droplets) has gone from the air it will have pulled all the dust down with it. you can then rebuild your old hard drive useing a suitable donor for spares. if the data isnt that valuable and you fancy soem DIY :)
the main thing is to keep it all totally dust free . That's why they are constucted in a controlled enviroment. The slightest bit of dust will corrupt the data. If the information is very important to you you then get it done properly. turbo 16v k-series 11.9@118.9 :)
9th Dec, 2007 at 10:40:20pm
Carl, if the drive spins up, but can't be read I'm 99% sure I can get some if not all of your data back. Obviously FOC. Give me call buddy On 15th May, 2009 TurboDave said:
9th Dec, 2007 at 10:48:39pm
I also have some software, kindly donated from internet land...But it does need the drive to be functioning. I can send it if you need it ?
10th Dec, 2007 at 02:30:40pm
PMed 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
10th Dec, 2007 at 04:04:27pm
I've got that software too stevie, made by ontrack, there is a few out there, it strange how some work with some problems, but not others and visa versa. On 15th May, 2009 TurboDave said:
10th Dec, 2007 at 04:31:40pm
as afr as i'm told it wont spin, something about reading heads jamming it,,
