| Home > Help Needed / General Tech Chat > Turbo SU HIF6/HIF44 Carburettor - Need Some Info | |||||||
3 Posts Member #: 2134 Junior Member |
11th Dec, 2007 at 08:03:58am
OK I'm trying to modify a non turbo carburettor to work on a blow through setup but in order to do so I need to work out a few things about how an SU works under boost.
11th Dec, 2007 at 11:02:04am
This has been covered in detail on here before, do a search for carb differences.
11th Dec, 2007 at 01:25:31pm
try this one
Edited by Turbo Tel on 11th Dec, 2007. website:- http://www.terryhunt.co.uk
11th Dec, 2007 at 10:13:33pm
Thanx for the help, Ive had a look around the site for a few hours before I posted and couldnt find the info I needed but that clears it up for me.
12th Dec, 2007 at 08:29:04am
It's quite interesting how the PPC gang managed to use the standard 2"SU carbs on their Roller for turbo use.
12th Dec, 2007 at 02:14:17pm
I guess if you have enough pressure even if some of it leaks out it would still work.. website:- http://www.terryhunt.co.uk
12th Dec, 2007 at 10:13:42pm
Yeah sealing the Dashpot is too easy of a job to not do it, just some insta-gasket would be enough to seal it up for small amounts of boost. If you were going more just mill a groove into it and chuck in an o-ring. |
