| Home > Wanted > suitable lsd crown wheel and pinion | |||||||
![]() 134 Posts Member #: 664 Advanced Member South Wales (chepstow) |
13th Dec, 2007 at 08:46:59pm
Im after a 3.1 ratio i think and have a straight cut close ratio box with1.1 drops and running 165/55/12 wheels and tyres cheers rob
13th Dec, 2007 at 08:53:14pm
i believe you will have to modify a helical one to get 3.1 or lower (i.e higher gearing) "Turbo's make torque, and torque makes fun"
13th Dec, 2007 at 09:02:47pm
what machine a standard crown wheel
13th Dec, 2007 at 09:20:32pm
yes, the highest you can get (sc to fit lsd) is 3.4 "Turbo's make torque, and torque makes fun"
16th Dec, 2007 at 06:47:30pm
Can i change the drop gears to get round the low gearing
16th Dec, 2007 at 07:41:28pm
21st Dec, 2007 at 09:44:59pm
already got the lsd
21st Dec, 2007 at 10:06:25pm
youll have to machine a std cw to fit it then "Turbo's make torque, and torque makes fun"
21st Dec, 2007 at 11:02:37pm
i thought it was much better to machine the lsd casing than the crown wheel? as when maching the crown wheel it became fairly weak?
![]() 3184 Posts Member #: 628 Post Whore a LIL fishing village on the coast - Newcastle Upon Tyne |
22nd Dec, 2007 at 09:26:05am
not to get involved too much, but imho machining anything at that end of the system is a recipe for diff / CW failure, if it mattered that much mate i would flog ure present LSD and do what Bat said mate, that way you know the tollerences etc have been checked by the good people at quaife.
On 17th Aug, 2009 Jay#2 said:
I doubt I'll be dipping into the 13's like you did though! |
22nd Dec, 2007 at 12:03:50pm
22nd Dec, 2007 at 11:07:25pm
sorry, i mean machine a std cw to fit on a lsd type diff, whether you machine the casing or not is down tot he manufacture of diff used (this is how i understund it anyway) "Turbo's make torque, and torque makes fun"
