| Home > Help Needed / General Tech Chat > Coolant loss, any ideas? | |||||||
158 Posts Member #: 551 Advanced Member Ashington W.Sussex |
17th Dec, 2007 at 10:58:51am
Hi all
17th Dec, 2007 at 01:19:17pm
What temperature cap do you have on the rad?
In the 13's at last!.. Just |
17th Dec, 2007 at 01:25:47pm
No idea, didn't know you could get different temp rated rad caps? |
17th Dec, 2007 at 01:30:47pm
Pressure rating not Temperature
17th Dec, 2007 at 01:32:11pm
My friends Clubman was pissing coolant all over the place due to an incorrect cap. He changed it and has not had a problem since (apart from being hit by an artic, but that's another story).
17th Dec, 2007 at 01:43:11pm
The cap I am using I think is the original which came from a 1983 1000cc Mayfair. Do I therefore need to get a heavy duty one? |
17th Dec, 2007 at 01:53:59pm
I can have a look to see what mine is when I get home. Unless anyone knows off the top of their heads.
17th Dec, 2007 at 02:23:22pm
could be the rad cap leaking,
17th Dec, 2007 at 06:51:32pm
17th Dec, 2007 at 07:36:46pm
Have you overfilled the rad, causing it to come out when it gets upto temp? |
17th Dec, 2007 at 10:19:37pm
I must admit I have been filling it up well over the top of the cores and I have also just checked the radiator cap and it is the 15lb one. So may just be user error with overfilling. |
17th Dec, 2007 at 10:37:40pm
17th Dec, 2007 at 10:38:48pm
If it's evacuated iself after getting up to full running temp and you don't top it up again and it's still filled over the cores and it doesn't throw out anymore then I wouldn't worry. I know there is an easier way of saying all that! On 7th Nov, 2008 Nic said:
