Home > General Chat > turbo dizzy or mega jolt
alandavies215
Member #: 1844
BURNTWOOD, staffordshire
hello
just wandering what the price difference is and the work involved in fitting both, if it works out the dizzy is cheeper and less work i might go for that untill other engine comes back
thanks
Dizzy is probably cheaper (if you can get a decent second hand one) and easier.
But MJ is not difficult to fit, nor is it expensive.
Not much help really lol!
I would go Megajolt (I am going Megajolt!) you will not look back!
MarkGTT
Member #: 1194
Shropshire.
Think most people on here use Megajolt, its a bit more expensive (£200 ish should get you everything you need) but much more versatile.
Star Mag
Member #: 375
Leicestershire
Save your pennies and get megajolt i wish i had done it years ago! And once you have it it can be transferred from engine to engine!
You may get a small fuel saving and usually you'll get more power lower in the rev range.
shane
Member #: 1246
Lowestoft, Suffolk.
I had a dizzy with an advance cure tailored to my engine (998) and what I spent on that I managed to get all the parts for my MJ set up, and the MJ is far more versatile, wish I knew about it a few years ago.
Shane
Yeah I'd agree with all of the above.
It is more expensive, a little more hassle to fit, but well worth the extra effort and pennies.
Another point to think about, is if your considering fitting a front rad or intercooler it free's up valuable space up front. *wink*
I forgot the mention the most important thing *surprised* With MJ it doesn't matter how much it rains, your engine keeps running!
I liked the dizzy, I've not had any gain with the mega jolt. just had all the extra work fitting it. But them my dizzy was set up well on the rollers and wasn't just plonked in.
