| Home > Help Needed / General Tech Chat > best way to get cold air into SU | |||||||
![]() 152 Posts Member #: 1662 Advanced Member manchester |
23rd Dec, 2007 at 12:29:11pm
hi,
Edited by aml on 23rd Dec, 2007. |
23rd Dec, 2007 at 01:10:52pm
The turbo plenum is a neat way to do it. All you need then is a bit of flexi hose and a unversial K&N (which you could reuse on the turbo cnversion!) |
23rd Dec, 2007 at 02:09:40pm
i used the plastic air feed pipnig from unger the wing as a cold air feeds it worked ok but probably not as well as a front mount air filter or ram air box like the miglias. Drives
23rd Dec, 2007 at 02:32:25pm
thanks so far! can anybody, or know of someone who could make a custom plenum for my needs?
23rd Dec, 2007 at 02:45:09pm
23rd Dec, 2007 at 02:52:40pm
The turbo plenum has a restrictor though so this would need to be a stub stack for NA applications.
Edited by Jay#2 on 23rd Dec, 2007. On 7th Nov, 2008 Nic said:
23rd Dec, 2007 at 03:04:58pm
thanks jay#2, i had just noticed the restrictor ring, what is a stub stack? which vizard book? cheers Edited by aml on 23rd Dec, 2007. |
23rd Dec, 2007 at 03:18:59pm
A stub stack is like a really short trumpet at the mouth of the carb that has a neat radius that, in short, smooths airflow into the carb mouth. It's in the 3rd edition of Vizards book, page 57 onwards. The air filter setup that's in it is not longer available but it wouldn't be too hard to knock one up. And I am wrong, it has a plenum actually! On 7th Nov, 2008 Nic said:
23rd Dec, 2007 at 03:21:59pm
Edited by Bat on 23rd Dec, 2007. VEMs Authorised Installer / Re-seller. K head kits now available!
24th Dec, 2007 at 02:59:44pm
i will contact nic about a custom plenum, i can see this being an interesting install lol, will post pictures up when finally sorted |
