Home > General Chat > DVD Authoring
Neil8p
Member #: 65
South Yorkshire
I've never played about with creating DVD's before and I've got 15Gb of video I want to put on DVD. It's lots of smaller MOD files (biggest is just over 1Gb), but no editing is required mainly because I can't be arsed at this stage.
I understand I need some DVD authoring software. For starters Cyberlink power producer came with the camera, I've found Sony's Click to DVD on my work laptop, and I have a 30 day trial version of roxio easy media creator. I've not used any of them yet, what I'm after is a pointer in the right direction of the easiest way to get the vid onto DVD. If there's a better way I don't mind spending on the right software to do the job.
I'm hoping there is a fairly straightforward way to do this as I've not got the time to spend hours messing with complicated software.
Thanks in advance :)
Try Windows Movie Maker, comes free with XP *wink*
It's in the Start menu > Accessories folder.
Ollie
Member #: 1380
I tend to use Adobe Premiere to capture the video from camcorder & edit, then export the edited version to .avi.
There is also a program called Adobe Encore this can be used to create a dvd main page, eg. exactly how a retail dvd loads. Special features, chapters, extras, movie - flash intro etc etc
There are many programs to encode .avi or .mpg files to dvd .vob's & .ifo's...
I personally use a program called "convertXtoDVD" to encode the video files into a burnable dvd format.
and to finish off, Nero to burn the encoded files from the HDD to dvd.
Edit: I forgot to add that there is a freeware software out there called "dvdshrink" that allows you to compress your encoded files so that it can fit onto the 4.7gb disk
Edited by Ollie on 30th Dec, 2007.
colas
Member #: 102
Pennsylvania USA
I use Adobe encore for authoring. Its really easy to use
