| Home > Help Needed / General Tech Chat > Idles too fast | |||||||
30 Posts Member #: 1898 Member BRISTOL |
1st Jan, 2008 at 08:10:40pm
Hi guys, im new to this site and i hope you can help me with my new engines teething problems.
![]() 368 Posts Member #: 362 Senior Member durham area |
1st Jan, 2008 at 08:18:16pm
sounds like its to rich at idle try leaning it of and adjust the throtle as you go. love that straight cut scream!!!
1st Jan, 2008 at 08:24:26pm
Cool, i'll try that. not sure if its too rich tho as i have checked the plugs and they look ok. |
1st Jan, 2008 at 08:58:14pm
173 Posts Member #: 873 Advanced Member Thatcham, berkshire |
2nd Jan, 2008 at 11:28:38am
are you running a dizzy, when i was running one before i went to megajolt i had the same problem as you it turn out to be a duff module, borrowed a mates on and it fixed it straight away |
2nd Jan, 2008 at 04:03:39pm
ive tried to set up the timing with vaccum advance off but it still does the same.
2nd Jan, 2008 at 04:54:16pm
Does it just cut out suddenly or wind down and die out after a few seconds? On 7th Nov, 2008 Nic said:
![]() 368 Posts Member #: 806 Senior Member Cirencester, Gloucestershire |
2nd Jan, 2008 at 07:15:18pm
have you checked the fuel pressure?
3rd Jan, 2008 at 04:01:40pm
It just cuts staight out, it doesnt die after a few seconds.
5th Jan, 2008 at 10:05:29am
keep trying though your get their let us no what it is?
7th Jan, 2008 at 07:24:02pm
Hi guys,
7th Jan, 2008 at 07:25:48pm
Didnt mean to say "wins".
7th Jan, 2008 at 07:31:16pm
you didnt try the module yet well if you did you didnt say. its worth a go mate for the case of unscrew old one and borrowing your mates one. that what was wrong with my car in the end sounds like same symptons as i had and i tried everything too. |
7th Jan, 2008 at 07:33:25pm
cool. i completely forgot to check that. will do so as soon as i get a chance
11th Jan, 2008 at 08:38:59pm
WOOO bleeding HOOOO!
12th Jan, 2008 at 09:12:09am
no worries mate its nice to put input back into the site. information can be price less and save you hours. good luck with the rest of project |
12th Jan, 2008 at 10:07:26am
My module had been on its way out at chrismas. the car was stumbling when trying to part throttle accelerate at 2000 ish rpm unless you buried your foot. It was also firing too early when cranking, which made starting a painful process.
Edited by minimole23 on 12th Jan, 2008. On 7th Oct, 2010 5haneJ said:
