| Home > Help Needed / General Tech Chat > Supercharger/idle/fuelling issues | |||||||
![]() 56 Posts Member #: 1901 Advanced Member Bolton |
4th Jan, 2008 at 12:26:53pm
Hi guys, hope this is in the right place.
4th Jan, 2008 at 12:39:59pm
What system are you using for idle air control?
4th Jan, 2008 at 12:47:33pm
Exhaust leak? Lambda sensor knacked?
4th Jan, 2008 at 12:50:00pm
As far as I know it uses an IACV from the MPI? |
4th Jan, 2008 at 12:52:42pm
On 4th of Jan, 2008 at 12:47pm danboy said:
Exhaust leak? Lambda sensor knacked? Regards Dave I'm pretty sure I have stopped all the exhaust leaks. The lambda seems to read properly on the live screen at idle and responds when the fuelling is changed. Cheers Chris |
4th Jan, 2008 at 12:52:55pm
Can you do a datalog and post it here?
4th Jan, 2008 at 12:54:16pm
I'm not sure how!? I got the software with the wideband controller but could not get it to connect to the laptop when I hooked it up.
4th Jan, 2008 at 01:23:30pm
On 4th of Jan, 2008 at 12:50pm captain_cabinet said:
As far as I know it uses an IACV from the MPI? I would check that it is working correctly. Undo the two screws, take it out of the housing, connect it back up and switch on the ignition. It should open fully at cold start. That's assuming that the Emerald ECU is setup correctly. Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
4th Jan, 2008 at 01:38:28pm
As far as I know it uses an IACV from the MPI? I would check that it is working correctly. Undo the two screws, take it out of the housing, connect it back up and switch on the ignition. It should open fully at cold start. That's assuming that the Emerald ECU is setup correctly. I will try that as soon as I can. Thanks Chris |
4th Jan, 2008 at 04:47:59pm
Id refrain from messing around with too many settings.
Edited by Nic on 4th Jan, 2008. |
4th Jan, 2008 at 05:00:50pm
On 4th of Jan, 2008 at 04:47pm Nic said:
Id refrain from messing around with too many settings. I know stuart has spend many hours refining his maps and then spends alot of time tuning in the cars to make sure they are right Buy fiddling around with it too much you run the risk of putting alot of variables in to the car which wont help it run at all If your having idle problems then it could well be another air leak, a hose or connector incorrect, or somehow your managed to adjust the map, maybe see if stuart can email you a base map to try However it may be for the best just to get it down there really I know exactly what you’re saying and changing things on the map made things worse when we tried to sort it initially and I went back to the original map I had saved. I haven't done anything without referring to Stuart first, and he talked me through what kind of lambda values I was aiming for at idle etc. I just wondered if there was something obvious I was missing. I'm sure I've checked everywhere for air leaks etc I just don't understand how it can seemingly run perfectly for up to a week and then suddenly soot up or refuse to idle or both. I will check the obvious stuff again and drop Stuart another line to maybe take it back down there. Thanks for all the advice it's given me some stuff to think about. Cheers Chris |
4th Jan, 2008 at 05:10:37pm
