| Home > Introduce Yourself > Nooooooob here! | |||||||
998 Posts Member #: 2178 Post Whore Leyland, Lancs |
7th Jan, 2008 at 09:43:34am
Hey guys.
a breif struggle ensued but Will emerged the victor with a pair of undies in his possesion On 21st Sep, 2009 apbellamy said:
No, but you did chuck your guts up over my front gate the Saturday before! You even managed to get a bit in your arm pit... |
Site Admin 6297 Posts Member #: 1 The boring bloke who runs this place. Berkshire |
7th Jan, 2008 at 09:55:44am
Welcome! Sounds like a cool project.
7th Jan, 2008 at 09:59:24am
Yeah, Mini in the Pod sounds much better. Perhaps you should suggest that to them! On 15th Jul, 2009 fastcarl said:
7th Jan, 2008 at 10:34:00am
7th Jan, 2008 at 01:46:03pm
Well, I've just booked it in with Rob at Minisport for Friday afternoon - he really seems to know his stuff and has done wonders with a couple of my mates Mini's.
![]() 3756 Posts Member #: 1709 I like granny porn. LONDONSHIRE |
7th Jan, 2008 at 01:54:32pm
hi welcome to TM...
I bet my first wank came quicker than your first mini turbo These new modern turbos with their quick spool up time, would make the competition harder. On 15th Aug, 2011 robert said:
phew!!! thank you brett for smashing in my back doors .( not something i imagined writing... EVER) |
7th Jan, 2008 at 01:56:43pm
Welcome mate,
In the 13's at last!.. Just |
7th Jan, 2008 at 02:24:55pm
On 7th of Jan, 2008 at 01:56pm theoneeyedlizard said:
Welcome mate, Minisport?!?! There must be another rolling road nearby that could do the job properly for you. If it's set up correctly and has an intercooler 10psi should not be a problem at all. Without an intercooler and the standard CR you will be best to keep it no higher than 7psi which is the standard boost. However, it's likely that you do not have an ECU, in which case you will only have 4psi. Browse through the beginners tech. You will find everything you need there. Yeah, there's no ECU in, so it'll be running 4 PSi then. Hence it feels like its got no guts - well, thats not really fair, it is quicker than my MPi, but my MPi only has 70bhp. Rob at Minisport really does know what he's doing when it comes to setting cars up. I wouldn't have an engine built by Minisport, but I've got no problem letting Rob set my fueling and timing. Most of the other places round me either don't have a rolling road, or don't want to mess about with Mini's. Never had a problem yet with Minisport so I'll see how I go. 7PSi seems a little low - I know its a standard lump, but my mate just achieved 117bhp with a completely stock Turbo A+, no intercooler, running 12 PSi with clutch slip and the fueling was spot on, no detonation etc... And he drives it every day!!! I'm not convinced that 12 PSi is a terribly good idea, but I thought I'd be able to stretch to 9 or 10 PSi. On 15th Jul, 2009 fastcarl said:
7th Jan, 2008 at 02:54:50pm
I'm not aware of the details of a Facet gold top, but if it is an interrupter type pump it isn't really suitable for a turbo engine, as these use fuel pressure 3 to 4 psi above boost pressure. As you are running only low boost currently then your total fuel pressure may only be 8 or 9 psi which you may get away with on an interrupter pump, however go much higher on boost and I personally think you may struggle, ideally you need to fit a rollervane injection type pump, these are capable of 3 or 4 BAR fuel pressure.
7th Jan, 2008 at 03:10:39pm
Well, I was told its a Facet Gold Top, which according to last months Mini Magazine is an interrupter type pump. However, I've just been out and had a look at the pump, and it looks nothing like the pumps in the picture in the mag.
7th Jan, 2008 at 04:52:45pm
It sounds like a turbo pump which is the following...
On 7th Nov, 2008 Nic said:
7th Jan, 2008 at 05:00:28pm
Thats the daddy! So I've got the right pump for the job then. Well, thats one thing sorted. Wonder why they said it was a Facet then??!! Strange.
7th Jan, 2008 at 05:04:28pm
7th Jan, 2008 at 05:15:08pm
On 7th of Jan, 2008 at 05:00pm Coupe said:
Also I find odd, is that the original electronic ignition was removed and replaced with points. Any idea why someone would do this? I'm guessing I should get an Aldon Ignitor or something in there pronto? to get the correct advance for the turbo timing.. however as Gavin says get a megajolt in there if your going to upgrade.
8th Jan, 2008 at 09:38:00am
Megajolt is on the list for when I build the new motor and box - didn't realise how cheap it was! On 15th Jul, 2009 fastcarl said:
11th Jan, 2008 at 11:44:15am
Hello and welcome -MINI CLUBMAN 1380 TURBO- |
1300 Posts Member #: 829 Post Whore essex |
12th Jan, 2008 at 09:49:01pm
hello 1293 Turbo mini
), so now its my turn!
