| Home > Technical Chat > Too much advance???? | |||||||
![]() 189 Posts Member #: 1774 Advanced Member Sydney AUS |
8th Jan, 2008 at 12:10:11pm
Edited by pristic on 8th Jan, 2008. 1132cc Turbo ~120 bananas ATW - Fun Fun Fun
8th Jan, 2008 at 12:16:11pm
8th Jan, 2008 at 12:28:26pm
Yeah, its with vac advance connected
![]() 6753 Posts Member #: 828 Post Whore uranus |
8th Jan, 2008 at 01:35:23pm
peter ,test it with the vac advance unconnected , that will give you a figure to compare with others , i think theres about 15 edegreees in the vac ,so that would put you at 28 ish ? that sounds about right !
8th Jan, 2008 at 03:05:36pm
On 8th of Jan, 2008 at 01:35pm robert said:
peter ,test it with the vac advance unconnected , that will give you a figure to compare with others , i think theres about 15 edegreees in the vac ,so that would put you at 28 ish ? that sounds about right ! regards robert I think Robert is correct, your real advance is in the 28 degree area, when you free rev the engine its not under load so 40 odd would be expected.. Driving without the vacuum pipe connected should feel fine, the vacuum advance is just there to advance the ignition when not under load to save fuel and emissions. website:- http://www.terryhunt.co.uk
8th Jan, 2008 at 08:58:21pm
Ah ok! Sounds good!!
9th Jan, 2008 at 04:12:37pm
dont forget the macanical advance as well this will bung some more on top of the 28.
10th Jan, 2008 at 09:32:36pm
On 9th Jan, 2008 turbo hogster said:
dont forget the macanical advance as well this will bung some more on top of the 28. best bet run no vac and lock machnical for now and set at 26 deg and no more. 10 degrees of static advance, plus 18 degrees of mechanical advance (turbo dizzy) and you get 28 degrees. add the vac advance (if any) and you have your "total" advance. website:- http://www.terryhunt.co.uk
11th Jan, 2008 at 05:00:28am
Thanks Lads. Yeah, looks like it was vac advance throwing us off.
Way too much!
