| Home > Help Needed / General Tech Chat > Marks on bores | |||||||
13th Jan, 2008 at 10:56:38am
I've got some vertical marks on my bores. See link below...
In the 13's at last!.. Just |
13th Jan, 2008 at 11:09:17am
it will run and will be ok, but.... down on power a tad and may use oil
13th Jan, 2008 at 12:15:35pm
it looks like bad det there mate, best to pull out piston and check either that or broken comp ring, and does look deep in one pic, i recon rebore time. always looking for them bigger bunches of bannanas |
13th Jan, 2008 at 12:18:13pm
Rebore time???
13th Jan, 2008 at 01:23:20pm
Rebore time for sure! For every % leak down you're seeing, you're missing the same % in power.
13th Jan, 2008 at 01:42:55pm
Bollocks! I'm really f*cked off now.
13th Jan, 2008 at 02:46:29pm
Why, you'll end up with something better. It's all good! On 13th Jul, 2012 Ben H said:
13th Jan, 2008 at 02:58:19pm
is this a reasonably recent rebore to start with,
13th Jan, 2008 at 04:11:08pm
you might be right carl bit hard to tell from a pic always looking for them bigger bunches of bannanas |
13th Jan, 2008 at 04:20:03pm
It's done approx 2000 miles
13th Jan, 2008 at 05:02:44pm
so the bores will not have worn at that milage, i'd get it honed for what it'll cost, tell the machine shop to hone untill it measures 0.06 over skirt dia, and see what they look likem.
13th Jan, 2008 at 05:04:27pm
Ive re-used worse before lol....
13th Jan, 2008 at 06:49:00pm
p.m sent gary:( no longer a series, but still 1.3 turbo.
13th Jan, 2008 at 07:06:14pm
I'd attempt a hone and then see what it looks like as per fastcarls instructions.
13th Jan, 2008 at 09:28:30pm
On 13th Jan, 2008 Carl said:
p.m sent gary:( Thanks Carl, please don't feel like I was trying to make you out to be an arse with this post. We all know that you are a decent, honest fella!
For the record - Carl has offered to buy it all back from me. Hence the decent, honnest bit above. I just need to get some options sorted. Is there anyone local that would be able to give me a hand to strip it so that I can get it honed? I really wouldn't feel comfortable doing it myself. Cheers all In the 13's at last!.. Just |
13th Jan, 2008 at 09:36:35pm
where abouts in essex are you?
13th Jan, 2008 at 09:41:21pm
I'm in Harlow J7 off the M11.
13th Jan, 2008 at 09:43:32pm
13th Jan, 2008 at 09:45:13pm
Im no expert, but i reckon alot of that will hone out, you may be left with some scores, but i know my bores arent perfect and they still go ok
13th Jan, 2008 at 09:54:56pm
That pic makes it look a lot worse than it is.
13th Jan, 2008 at 09:59:36pm
I may be able to later in the week
13th Jan, 2008 at 10:09:15pm
I need to give Carl an answer asap.
13th Jan, 2008 at 10:09:49pm
If you try honing, flex hones would be unsuitable. You'll need a proper stone hone finish. On 13th Jul, 2012 Ben H said:
13th Jan, 2008 at 10:14:17pm
Cheers V, I'll keep that in mind.
13th Jan, 2008 at 10:32:51pm
to be fair, a newly maching block is in the region of £140 so its not the end of the world, you have all the expensive parts. (i know £140 is a fair amount but you can see where i'm coming from)
