| Home > Technical Chat > Biggest valves in a 12G295 head | |||||||
18th Jan, 2008 at 11:49:42pm
I feel like a bit of a numpty posting this but I can seem to find the answer anywhere. Does anyone know what the biggest valves sizes are that can be used with a 12G295 head without pocketing the block (998 without a rebore) or offsetting the valve guides?
19th Jan, 2008 at 12:04:31am
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=8029
19th Jan, 2008 at 12:07:17am
and heres how mine ended up, very similar to wil_h's head
Edited by joeybaby83 on 19th Jan, 2008. "Turbo's make torque, and torque makes fun"
19th Jan, 2008 at 09:28:49am
I've used 33mm inlets and 26.5mm exhausts on Sturgeo's NA 998 12G295 head, and am doing another set for Axel's.
19th Jan, 2008 at 09:38:02am
You'd need a severly skimmed head and high lift cam to get the valves to hit the block on a 295. On 13th Jul, 2012 Ben H said:
19th Jan, 2008 at 12:22:26pm
I had standard 1275 valves in a 295 with a Kent 266 and it was fine. Head was skimmed to suit non cooper too. On 7th Nov, 2008 Nic said:
19th Jan, 2008 at 01:22:06pm
19th Jan, 2008 at 02:08:40pm
Done a bit of maths:
19th Jan, 2008 at 05:11:42pm
Yep i put the valves from a 940 in my 295 and they touched the block. Head was skimmed but not excessivly as it had flat top pistons and was only 10:1.
19th Jan, 2008 at 06:42:33pm
Measure the distence from the valve face to the head face. You'll be surprised. On 13th Jul, 2012 Ben H said:
![]() 6753 Posts Member #: 828 Post Whore uranus |
19th Jan, 2008 at 06:50:41pm
so maybe 266 cam lift is ok and 276 not ok ? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
19th Jan, 2008 at 06:56:58pm
Mine had a 266 and the head had the usual (80thou?) off it to suit the non-cooper 998. But alas I can't say much about the head becasue it was done (badly) by the previous owner. Maybe he offset valves or something? On 7th Nov, 2008 Nic said:
