Home > Help Needed / General Tech Chat > Carbing
Alex1340
Member #: 111
Loughborough
Hi Peeps. I've got my 1380 out at the moment and i'm wondering what carb/carbs to put on it when it goes back in. Its currenty on a hif44 but im thinking of swaping on to twin Hif38 or a 45 weber.... only think is im not cutting the bluk head so i would end up with a manifold like this http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...:MEWA:IT&ih=009
or i fit the twins on a maniflow manifold. what do you think?? need help to make my mind up.
Thanks
Stick with the 44 :)
Don't use one of those horrible manifolds, unless it's holding the garage door open!
no point fitting a weber on a shite manifold, you will end up with a poorer flowing setup than you already have.
i had twin 1.5 su's (HS4's) on a maniflow steel inlet and they looked beautiful and performed really well, but what a pain in the ass (and wallet) to setup
i think i ended up with MME needles on with yellow dashpot springs on my 1380 with stg 3 head, 296 cam, 1.5 rockers, 11:1 cr, LCB etc
not sure what the hif version of the MME needle is, but you can look its profile up in tuning books and find a match for those if you do decide on that route.
personally, if it were me id consider leaving the hif44 on unless its definately the limiting factor powerwise
turbo hogster
Member #: 178
stowmaket suffolk
you would only gain about 5hp tops with the webber and and about 3-4 with the teins and both will drink fule for england.
i had a 44 on my 1380 it went very well and was economical to
Alex1340
Member #: 111
Loughborough
who does a good inlet manifold for the HIF44? also going to put a ram stack thing on it, MED do a nice looking one which they claim will add 5bhp which seems hopefull but for £85 should do somthing good.
Alex1340
Member #: 111
Loughborough
no one?
just get a itg filter for it *tongue*
I don't know to be honest, don't maniflow do one for the HIF?
any decent alloy one should suffice i would think?
miniminor63
Member #: 672
The oversills police
Oslo, Norway
MME needles tend to make it slightly rich on the bottom of the rev range though. but they are very good towards the top. They are one of the richer needles available actually.
