Home > Help Needed / General Tech Chat > Changed steering rack today *pic* need a nut can someone help :(
jamesfawcett
Member #: 218
Bingley, West Yorkshire
Hi everyone, done the horrible job today of changing my steering rack.
Its absolutely pissing it down, its so muddy and cold, but whats worse is ive got right to the end and cant find the locking nut for the trackrod end :( Its a small one, that secures the trackrod to the hub.
It rained really badly about dinner time, and its just sunk in the mud, ive looked and looked and cant find it.
Cant believe ive got this far and got stuck on that!
Just asking a really big favour, because im stuck without a car now and cant get to the nut and bolt place, can anybody post me a nut for it? I will pay for it and for your time, cant beleive ive got to get a taxi tomorow now for work because i live so far out in the sticks theres not even any busses here!!
Edited by jamesfawcett on 20th Jan, 2008.
jamesfawcett
Member #: 218
ive just found this on ebay, a does anyone know if one of the nyloc nuts in there is the right size for the trackrod ends?
http://cgi.ebay.co.uk/Mixed-Stainless-UNF-...1QQcmdZViewItem
I think there's 2 different threads depending on the TRE you've got fitted :(
jamesfawcett
Member #: 218
do you know what they are? is one metric and one not? id order both types!!
I've seen a few different ones before, if its as per original it should be 3/8" UNF, if its aftermarket it might be M10 although it could be a fine pitch 10mm thread.
A cylinder head nut is 3/8" UNF if you have one spare, could get you out of the shite. Or otherwise a wheelnut is also 3/8" UNF.
danboy
Member #: 1381
You could, as a VERY temporary measure, use a wheel nut until you can get the correct nyloc.
Dave
jamesfawcett
Member #: 218
Thankyou, to play it safe i wont use it with a wheel nut ill wait for nylon ones to arrive, ive just ordered m10 and 3/8 ones from ebay thanks alot everyone
jamesfawcett
Member #: 218
Thankyou everyone, these turned out to be 3/8" UNF nuts, job done and back on the road :):)
Monster22
Member #: 39
Respect changing a rack in those conditions :)
Jason G
Member #: 1459
En-suite user
Braintree, Essex
These jobs always need doing in shitty conditions.
On 19th Jan, 2010 wil_h said:
Ric
Member #: 36
Basingstoke
fuck me, that's hardcore!
Have you got an intercooler on that badboy yet? Thats my next job, looking for inspiration.
Ain't that the damn truth!!
after 3 weekends dicking around with the suspension on my car i finally stoped it diving one way when braking by replacing the front brake hoses*oh well*
was one blocked or something? ive not heard that one before!
sometimes the rubber ones can "swell" internally, had it before with a clutch one.
i think it may be to do with brake fluid incompatibility.
ahhhh so it restricted the flow on that side and gave you less efficiency so yanked you to the other side?
yep, and when i let of the brake it held fluid in and yanked the other way....
Jay#2
Member #: 648
Northern Ireland (ex AUS)
Sounds like your mini is trying to kill you! I had that with the clutch hose though.
On 7th Nov, 2008 Nic said:
naeJ
m
felt like it too......
