| Home > Help Needed / General Tech Chat > Brakes very poor DUNNO WOT ELSE TO DO | |||||||
16 Posts Member #: 1685 Member rochester kent |
24th Jan, 2008 at 09:10:29pm
Rite i have no idea wot else it could be the peddle is still really soft and barely stops the car and stays soft even if i pump the peddle loads of times it gets a little hard but not enough to make any difference
24th Jan, 2008 at 09:13:47pm
What calipers have you got on the front?
![]() 1913 Posts Member #: 1392 Pointless Post Whore Liverpool, North west |
24th Jan, 2008 at 09:14:04pm
fluid been changed?
Back once again like a renegade master |
![]() 966 Posts Member #: 358 Post Whore Snetterton, Norfolk |
24th Jan, 2008 at 09:23:39pm
The only thought is that the master cylinder isn't the right one for the brakes or needs new seals? When i did my brakes i thought i had wound the rear brakes to a suitable position, but it was nowhere near alothough sounded it. In the end i wound it right out so the brakes locked then came back and found a good point of adjustment. My car brakes really well now. |
24th Jan, 2008 at 09:27:54pm
The shoes need to be centralised before you adjust or they loosen up when you drive a bit. If you pump the pedal does it firm up? And if so, if you pump then hold it does it slowly go down? Sounds like there's still air in there or you need a new master cylinder. On 7th Nov, 2008 Nic said:
24th Jan, 2008 at 09:37:54pm
not being funny but did you rember to top the fluid back up... if you have new pads they will always not work was well as they are not bedded in that is what i have found on every car i work on at work. Drives
24th Jan, 2008 at 09:41:17pm
AIR STILL IN THE SYSTEM
24th Jan, 2008 at 09:43:49pm
also did you double check the feed to the new rear cylinder is on really tightly? Drives
24th Jan, 2008 at 09:58:29pm
right first of need to know when the brakes went soft. were they working and then you done something and they went soft. of did they just go soft?
24th Jan, 2008 at 10:14:56pm
On 24th Jan, 2008 BENROSS said:
AIR STILL IN THE SYSTEM if all is adjusted up correctley! get one of those pink rubber bleed hoses for around a £1 and use that if still no joy the seals may be passing on the master cylinder or the bias valve on the rear subframe may be duffed if its that set up keep us informed He's right - minis care fussy about bleeding, so do it manually in the other stated in the manual. Alex AlexF |
25th Jan, 2008 at 06:51:18am
calipers on correct way round ( bleed nipples at the top)? -MINI CLUBMAN 1380 TURBO- |
![]() 902 Posts Member #: 111 Post Whore Loughborough |
25th Jan, 2008 at 09:33:35am
I had a simular problem, turned out to be the master cylinder... seals had gone. didn't leak but got no pressure.
25th Jan, 2008 at 05:26:08pm
