Home > Help Needed / General Tech Chat > Oil blowing out breather
dave_spr88
Member #: 2014
Carlisle
Question for my friend who hasnt got internet.
Does anyone possibly know why his engine could be firing out oil from the breather on the rocker? and im not talking jusdt a little bit, its a fair amount its blowing out.
Any suggestions to what could be causing it?
Knackered piston rings?
weewheels
Member #: 1508
n ireland killyleagh
I would second that. Def' rings
I'm stupid Ive A fiesta with most of the bits to make my megajolt thingy. Thick or what!!!! OHHHHH and ive got a metro for free !!!!! Metros have become rare over here!!!!!!!!!
http://s216.photobucket.com/albums/cc273/weewheels_2007/
dave_spr88
Member #: 2014
Carlisle
I was thinking that, but the temp and pressure remains the same, no real movement. thats what puzzled me, plus it still goes like sh*t.
that can happen
Blocked breathers on the timing cover / transfer case.
The breather in the Rocker cover cap is supposed to draw air in.
The others should be connected to a vacuum.
Turbo Tel
Member #: 588
Delaware, USA
Both times I took my ring lands out that was the symptoms, not much at idle, gets worse as the revs go up and will only blow smoke out of the exhaust after a long period of idle, otherwise not a great deal out of the exhaust.. I would do a compression check as rings are the most likely suspect....
Terry
Edited by Turbo Tel on 28th Jan, 2008.
turbo hogster
Member #: 178
stowmaket suffolk
also my old one did when them stupid cheaper kn style oil breather got blocked i removed them and hey presto it stopped
I had the same and I thought my rings were shot for ages. But it turned out that my head gasket had blown where it wasn't torqued up enough.
Stupid cheapo torque wrench!
has the engine done starship milage ?
if so the piston ring are goosed like the lads say
steve w
Member #: 1917
AKA chargedzetec
had the same, headgasket had gone!
dave_spr88
Member #: 2014
Carlisle
thanks all i've passed the info to my friend and we are going to investigate over the weekend.
Thanks again all
Pull the head and inspect. Check the gasket. If that looks okay, you know that it will most probably be the rings.
just do a pressure test alot easier.
if all pressures seem fine drop a little bit of oil down the plug hole and redo the test. should see some differences and that would point to rings. 30 mins work and its diagnosed. if its neither of these, you havent wasted time, effort and money on a new gasket if its neither HG or rings.
then i would check your breather system for a blockage.
if there is not blockage THEN i would start to strip it down. because it could still be rings or HG
turbo hogster
Member #: 178
stowmaket suffolk
still ckeck all breathers first and remove any breather top cap filters too.
if it still does it then you are looking at the above, which is more likly but still do the check any way.
