Home > Technical Chat > Any other bike heads besides BMW k been fitted?
jimbob69
Member #: 2192
Huddersfield
Just a thought but has anyone tried anything else on an 'A' block?
Cheers James
I thought about fitting one from my suzuki x1
How ever the lack of valves meant that the idea didnt get very far
Did someone mention a 600cc Triumph head as the bore spacing was close?
jimbob69
Member #: 2192
Huddersfield
Well i have a spare zx9r lump kicking around but dont really want to tear into it without research!
Sam
Member #: 1686
Oxford
yes bat *happy*. if i can find a cheap one off ebay ill be looking into it, will be trying to put it onto a 998 though with an offset 120 thou overbore.
Edited by Sam on 13th Feb, 2008.
OMG Robert that's a big one
scooperman
Member #: 2234
Palm Beach Gardens, Florida
I tried to research this a bit, but bore spacing information is not on the web. So I go to Ebay, find anybody that is selling a used bike head, and send them a message asking if they have an old head gasket lying around on the workbench. Sometimes they will let me have a junk gasket for postage, sometimes they will sell it for a pittance. Forget the big bikes, the Jap bikes bigger than 750 have too much bore spacing, I am trying to find gaskets now for the 600s, later Hondas and Kaws look interesting.
scooperman
Member #: 2234
Today I dumped out the box of old head gaskets, nothing in the pile even close to a Mini, except the Toyota 3E, which was a 1.5L, 12-valve SOHC head, belt drive. Methinks one of these automotive smog heads could be a very tidy conversion, easier than a BMW bike head to adapt, if it already has a belt wheel hanging out the end. But of course the bore spacing of Minis is weird, very thin between cylinders, so normal heads like this one won't line up. For example the Toyota chamber volume must be big (it is a 1.5), so that makes me wonder if some welding could be done in the chambers to make them a little smaller, to better meet up with the Mini block bores. What else? Lots of Jap cars had 71mm bores and 16V heads, but I can't find any info on bore spacing. Does anyone have a gasket for a Nissan GA13DE (Sunny) or CG10DE/CG13DE (Micra) engine, or a Mazda B3 (Ford Aspire/Festiva?
Jordan
Member #: 1392
Pointless Post Whore
Liverpool, North west
I could get a fiat punto/cinquecento one to fit. But why would i want to do that?
jimbob69
Member #: 2192
Huddersfield
Silly question but as i have no access to a 1275 whats the bore spacing!? I only have a 998 block and was unsure how different they are
johnK
Member #: 690
Norfolk
Don't forget that the mini engine runs clockwise - when using the K head we run it "backwards" from its designed rotation - just as well those clever Germans put symetrical cam profiles in for us mini folk - just something else to look out for when searching for an alternative!
JK
If Carling made Mini engines
Advantage
Member #: 1450
Near Paris - France
I happened to check between a 998 head gasket and à Renault 1.2 16v and from what I concluded at the time it was quite good.
Good point is that it is doesn't have a silly camshaft for turbo application.
I think it calls for a double check
Ho, and I do own the Renault blueprint at 1:1 scale (I work there) so I 'll have another look ASAP
Rusty by nature
Now thats an Advantage
Advantage
Member #: 1450
Near Paris - France
Indeed, thought I have not be able to source one of those brand new 1.2 liter head and turbo (for free obviously)
Rusty by nature
ewan_me
Member #: 2251
Aberdeenshire
So, waht was the conclusion? Would it fit in theory?
what about peugeot engines? the cylinders are pritty close on the TU's and they did 16v heads for them too, may try up my 106 head gasket for the mini i have in my box :)
KLAS
Member #: 2380
Hamburg, Germany
i tried the Micra one, doesn't fit. like most others its close but not close enough
