| Home > Technical Chat > Is a charge cooler more efficient than an intercooler? | |||||||
1st Feb, 2008 at 12:06:03am
if you had an intercooler that when on, say over 10psi boost, it got a spray of water from a seperate small rad to help cool the air and you had a charge cooler, which would possibly be more efficient?
1st Feb, 2008 at 01:11:36am
in short, charge cooler in a mini ...........may be yes! "on the track"
1st Feb, 2008 at 02:41:19am
Water sprays generate a large amount of additional cooling. The spray has to be a fine mist though.
Edited by Sprocket on 1st Feb, 2008. On 26th Oct, 2004 TurboDave16v said:
1st Feb, 2008 at 08:17:28am
I guess one advantage of a charge cooler in drag applications is you could use ice/dry ice to further cool the coolant. Not very practical on the road obviously. On 7th Nov, 2008 Nic said:
1st Feb, 2008 at 11:17:39am
On 1st Feb, 2008 Jay#2 said:
I guess one advantage of a charge cooler in drag applications is you could use ice/dry ice to further cool the coolant. Not very practical on the road obviously. Muhahaha thats the plan for Avon! I'll be bringing a large cool box with me, packed full of ice (amongst the sausages, burgers, beers)!
Site Admin ![]() 9407 Posts Member #: 58 455bhp per ton 12 sec 1/4 mile road legal mini Sunny Bridgend, South Wales |
1st Feb, 2008 at 11:33:40am
I think it all depends what you use the car for, I think a charge cooler on a race car would not be much good to be honest, on a pro drag race car then it could work well On 15th May, 2009 TurboDave said:
1st Feb, 2008 at 12:49:43pm
We have heaps of dry ice here at work (and liquid nitrogen), hmmmm... I might try a spray bar for my IC set up just for craic. I presume charge coolers could weigh quite a bit though compared to an IC? On 7th Nov, 2008 Nic said:
1st Feb, 2008 at 12:55:17pm
On 1st Feb, 2008 Sprocket said:
Water sprays generate a large amount of additional cooling. The spray has to be a fine mist though. As the water vapour passes over the surface area of the intercooler, it evaporates, as it evaporates it absorbs sensable heat as latent heat and it is this that gives the additional cooling. The type of spray is very important, water dripping from the front of your car, wont do much other than wet the road. high pressure and fine mist jets are the key, garden sprinkler heads are of no use ![]() Reminds me of A-level physics but that was more than a few years back, and no I haven't kept my notes. Basically from what I remember you want to avoid saturation, a mist is alot more efficent than a soaking wet IC, due to the energy involved in coverting liquid to gaz inorder for it to evaporate. Sadly I can't rememberthe details, prehaps our friendly refridgeration expert can help out? Wow, I learned something at school that's come in usefull. Isambard Kingdom Brunel said:
![]() 6753 Posts Member #: 828 Post Whore uranus |
1st Feb, 2008 at 01:32:57pm
a n2o spray on the ic would be what minus 184 or something ,deff cooler than water lol Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
1st Feb, 2008 at 02:24:46pm
It all definately comes down to packaging. Whether one is ultimately more efficient than the other is academic when you condider the number of different installations possible.
1st Feb, 2008 at 04:52:46pm
i have a chargecooler and it seems to work a lot better than the intercooler i had. main reasons being the intercooler was too small as it had to fit in the car and also heat soak from the engine.
1st Feb, 2008 at 06:01:34pm
good info here guys cheers. i was more swaying towards an intercooler with a mist and i think that is the way im going to go. now ive got to do some research into the best way to get an appropriate spray onto the intercooler and how to trigger it.
1st Feb, 2008 at 06:25:46pm
1st Feb, 2008 at 06:48:51pm
The way ive always looked at it, which may well be wrong is:
1st Feb, 2008 at 08:13:02pm
i think youv got that spot on nic Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
1st Feb, 2008 at 08:14:14pm
YES!!!! It could be time for a new sig |
1st Feb, 2008 at 08:15:54pm
Hit...Nail...and Head come to mind! https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
1st Feb, 2008 at 08:21:34pm
im using a charge cooler, think its off a rs turbo anyway its a pace one. im using it because i havent got room for intercooler.
1st Feb, 2008 at 08:24:49pm
its going to work, itll be better than nowt, particularly on something like yours carl where you have modern gubbins to allow for correction on the timing and fueling |
1st Feb, 2008 at 08:25:17pm
im hoping to use both . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
1st Feb, 2008 at 08:38:18pm
On 1st Feb, 2008 robert said:
im hoping to use both . There's always one trying to be cooler than the rest!
1st Feb, 2008 at 08:41:50pm
im hoping to use both . There's always one TRYING TO BE COOLER THAN THE REST ![]() ba dom tissssshhhh |
![]() 1913 Posts Member #: 1392 Pointless Post Whore Liverpool, North west |
1st Feb, 2008 at 10:16:46pm
Charge coolers must weigh a bit more than intercoolers also. And intercoolers are easier to install if there is room.
Back once again like a renegade master |
