| Home > Help Needed / General Tech Chat > Starting the car | |||||||
![]() 862 Posts Member #: 1660 Formally Mini_Uk London |
1st Feb, 2008 at 06:06:23pm
Finaly got to the stage in starting the car..
Shit Happen's |
1st Feb, 2008 at 06:08:18pm
2nd Feb, 2008 at 12:23:51pm
On 1st Feb, 2008 Bat said:
Hi, Does the White wire with the red stripe have power on it when you try to crank it over? It will be located on the solenoid, either on the wing or the starter itself
Cheers, Gavin :) Well when i turn it over, all i hear is a click coming from the solinoid. I just noticed that when i turn the ignition on, the back and reverse lights come on .
errrrrrr what could it be ?? pleaseeeeeeeee :) everything seems ok on the electric side.. ? Cheers lads. Edited by Markie_D on 2nd Feb, 2008. Shit Happen's |
2nd Feb, 2008 at 12:28:04pm
flat battery then "Turbo's make torque, and torque makes fun"
2nd Feb, 2008 at 12:29:46pm
On 2nd Feb, 2008 joeybaby83 said:
flat battery then Well i charged it last night, and also had a mate try jump start me, but still same problem ? :( Shit Happen's |
2nd Feb, 2008 at 12:41:37pm
battery might be completely goosed? "Turbo's make torque, and torque makes fun"
2nd Feb, 2008 at 12:42:21pm
or your battery cable under the car might be feeked? "Turbo's make torque, and torque makes fun"
2nd Feb, 2008 at 12:44:40pm
sorry about all the posts, should just think things through before answering!
Edited by joeybaby83 on 2nd Feb, 2008. "Turbo's make torque, and torque makes fun"
2nd Feb, 2008 at 12:45:53pm
battery might be completely goosed? Hmmm maybe.. coz it was flat before i charged it. so maybe that's y the back lights are coming on. but now the horn stoped working.. fudge, i best buy new battery to see what kind would u recommend ??.. should i get it tested on a amp metre ? coz me mate has one up the road. what should it be on when i test it ? Cheers.. Edited by Markie_D on 2nd Feb, 2008. Shit Happen's |
2nd Feb, 2008 at 04:20:09pm
check that the soli is earth proberly on the inner wing if it is that type and all batt and earth conections are clean and tight.
45 Posts Member #: 2014 Member Carlisle |
2nd Feb, 2008 at 05:22:24pm
I think i may know the problem but it involves a bit of testing to find the fault.
2nd Feb, 2008 at 07:02:13pm
On 2nd Feb, 2008 dave_spr88 said:
I think i may know the problem but it involves a bit of testing to find the fault. Put a multimeter to the live on the solenoid, and check how much power is going to it. get someone to turn the key and check the power coming out of the solenoid if there is power then follow the lead to the starter, check that for power. One trick to try, short out the solenoid, get a spanner or something and connect the two lives together, then providing everything after the soleniod is fine it should turn over and start. I had the same problem when i bought my current clubby estate with the original engine that was in it. Doesnt take long, but does sound like soleniod too me. hope this helps Yep a feecked solenoid. good job i had a spare one. :) So turns over now, but havn't started it yet. Because i was told i have to set it up at top dead centre for the egnition timing before i start it up proper ? can someone give us little info please/ Thanks alot. Shit Happen's |
