Home > Help Needed / General Tech Chat > Adjustable boost with a supercharger ??
Alex
Member #: 1851
Woolavington, Zummerzet
While plotting & planning & collecting parts for my 'charged 1150, I've got to the bit with the dump valve, and this is where my sketchy knowledge is failing me...
I know I need a relief valve between the intercooler and the throttle body to prevent over pressuring, and that that is controlled by vacuum off the inlet manifold downstream of the butterfly.
If I'm right, I set the amount of pressure dumped by altering the amount of vacuum required to lift the valve.
The question is this:
Can I control that valve to dump pressure from in the car instead of clambering under the bonnet ?
If so, would it be possible to run on low boost for pootling around and then crank it up when required like with a turbo ?
Any typical dump valve should work ok.
Why do you think it needs adjustment ? Once its set to open early enough, and not leak under boost.....its a fit and forget item.
No you can't, as you'll have no vacuum to open the valve once you're on boost.
slater
Member #: 1291
Suffolk / Birmingham
You could jus have a pressure relif with adjustible spring pressure.
But dont relly see the benifit, its just wasting power driving the blower too fast.
The thing with superchargers is thet the amount of air they pump (and hence the boost generated) is set by the pulley sizes.
So altering the boost by dumping the air is a massive waste of energy; unlike a turbo, where you alter the speed of the compressor to make more or less boost as required.
If you can't trust yourself to just drive a bit slower, the best thing you can do is have a switchable rev limiter.
If you are on boost...why would you want vacuum to open it ?
You want part throttle vacuum to open the BOV. How it works isnt really any different to a turbo setup, although you might want teh valve to open a little easier.
Stevie .. He wants to use the BOV to control boost pressure by opening the BOV to vent it to atmosphere.
It is do-able. Many dont reccomend it, but quite a few have done it with decent results.
I almost considered it myself for a while.....then figured why the hell would I want to turn it down !!!!!!
