Home > Show Us Yours! > My ECU has arrived :)
My ECU has landed, it came yesterday from Hungary so I had to feed it before taking the pics *tongue*
Now all I've got to do it build it!
On board knock, EGT and WBO2 :)
ooooh no, I don't like that! *tongue*
Lol :)
How much is one of those then? Does it have coil and injector drivers on board?
Yes Tom, £300 :) Email on Friday saying it had been dispatched, on the doorstep Monday morning :)
Upto 8 inj drivers
COP ignition possible
ISCV driver
2 VR sensor inputs....
Jordan
Member #: 1392
Pointless Post Whore
Liverpool, North west
I seen sprockets not so long ago.
Looked smart the capabilities of the system.
One thing i am put off though is soldering it all together.
I tend to shake a bit. I cant eat peas off a fork *tongue*
Edited by Jordan on 5th Feb, 2008.
What do you get for your £300 then, I take it the board comes with the chips etc mounted, you just need to solder the plugs to the board? Did the £300 include that lambda sensor too?
I'm intrigued too (esp, as having gone down the MS route)... That's obviously primarily a surface mount board from the photos so why are they selling it with all of the SM bits installed but most of the discrete components DIY ???
I thought VEMS was only available fully built ???
Confused...
You can buy it built from the Uk importer, or in kit form from the manufacturer.
WBO2 sensor was £60 on top of the £300
You've got to solder the IGN and INJ drivers, plus the option chips such as stepper chip, EGT chip, 2nd VR chip and the big sockets *wink*
£330 gets you a built standard one + the prices for the options IIRC
It comes that way so you can customise it to your requirements eg number of ign and inj outputs ect...
Edited by Bat on 5th Feb, 2008.
You sir, are a comedy genius!!!!
Well done
3 weeks to go untill I can order mine! :)
Im taking the easy route and getting it prebuilt though. lol
Keep us updated how the build goes. I guess there is no such thing as a stim board for VEMS?
Thanks Nic :)
Matty .. I'm wading through the instructions... Not heard of a stim ...
Perhaps I should start making them *wink*
jbelanger
Member #: 831
Montreal, Canada
I guess you could use a JimStim to at least test some of it. But I'm a bit partial because I'm the one making them. Have a look at
Jean
http://www.jbperf.com/
Good plug Jean *wink*
barkiboi
Member #: 591
Rugeley, Midlands, England
Looks good shouldnt be too hard, reminds me of my college days... errr was atleast 3 years ago lol. Keep us posted am intrested in stuff you have to asseble your self.
Update time :)
It's all soldered together and fitted into the box. I've upgraded the firmware (thanks Sprocket :) )
Tested and calibrated my £4 MAP sensor *wink*
I only had one of those tiny surface mount chips to fit, it went alright, just needed a magnifying glass to check *surprised*
Jordan
Member #: 1392
How long did it take and how many swear words were used?
Well I never kept a close look at the clock and really took my time. Swear words were used when I cooked my finger a couple of times!
To be honest it wasn't the hardest job I've ever done, got Sprocket to ask when I want to double check :)
Wont be long now :)
this will be a serious consideration for me when i come to choosing. will have to do some proper indepth research closer to the time. only thing is that i know alot of people use and know alot about the megasquirt and i have not really heard as much about the vems. and as this will be the first time i will have been using a programable ecu i will be needing all the help i can get.
but like i said more research nearer the time.
I was/am in the exact same situation but there are a few guys very knowledgable on the VEMS unit that have answered my stupid questions! *wink*
Bat, if you need a test engine for your ecu....you know where I am. Lol Hope mine turns up before the weekend!
Funny that, Sprocket offered to test on his engine for me too *wink*
If you need it give me a shout :)
Lol.. I may take you up on that. My car is sat in the garage finished saying "start me, you know you want to". Lol
Now all I've got to do it build it!Gavin :)
do they eat chips ?*blush*
