| Home > Help Needed / General Tech Chat > Engine cuts out above 3500rpm | |||||||
28 Posts Member #: 1764 Member |
13th Feb, 2008 at 07:21:22pm
Hi all,
13th Feb, 2008 at 07:32:29pm
fuel pressure regulator working ok ? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
13th Feb, 2008 at 07:42:33pm
Tried two turbo carbs and two regulators, it ran fine on the metro. But has been sitting in the shop for a while now.
13th Feb, 2008 at 07:44:27pm
There are a few things that spring to mind.
13th Feb, 2008 at 07:44:50pm
Check that you are getting 3.5psi of fuel pressure on idle. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
13th Feb, 2008 at 08:03:06pm
On 13th Feb, 2008 wil_h said:
There are a few things that spring to mind. 1) Fuel pressure reg (as Robert said) 2) Plenum gasket missing extra hole 3) 9 V supply to ignition module rather than 12 V. This is if you have used the 9 V ballast coil supply. Will try that tomorrow thanks |
13th Feb, 2008 at 08:04:11pm
On 13th Feb, 2008 matty said:
Check that you are getting 3.5psi of fuel pressure on idle. Was about to ask how I know the regulator is working. So I need to mesure the pressure between the regulator and the carb right? |
13th Feb, 2008 at 08:10:24pm
13th Feb, 2008 at 08:37:56pm
On 13th Feb, 2008 Bat said:
Hi, Yes, you should get 3.5 ish psi with the ignition on... Cheers, Gavin :) My bad..
To check it, take the fuel supply hose off the carb that runs from the FPR and put a pressure gauge on it (I used my boost gauge which seemed to be fine). If its a lttle high or low adjust the centre screw on the FPR untill its right. If your struggling to get adjustment to 3.5psi take the FPR apart and have a look at the diaphragm its possible that this has weakend, stretched or even split if its fairly old! If all the other checks come back ok, try the 'T' piece trick. (if you do a search you'll find many different threads on this). https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
14th Feb, 2008 at 11:21:05am
that 9volts thing is a good point . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
14th Feb, 2008 at 12:18:13pm
I say coil rather than fuel too. On 7th Nov, 2008 Nic said:
15th Feb, 2008 at 10:12:52pm
Fuel pressure seems allright, tried different coils, voltage is 12 volts..... out of options here....
16th Feb, 2008 at 08:22:08am
fuel filter blocked ?
16th Feb, 2008 at 08:50:08am
Where are you, maybe someone could pop round and help Fastest 998 mini in the world? 13.05 1/4 mile 106mph
![]() 1566 Posts Member #: 36 Post Whore Basingstoke |
16th Feb, 2008 at 09:02:56am
what about the breather anti run on thing on the side of the carb. Has this been blocked properly? |
16th Feb, 2008 at 09:35:03am
has it ever run ok with the present setup? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
26th Feb, 2008 at 10:15:03am
On 16th Feb, 2008 wil_h said:
Where are you, maybe someone could pop round and help The car is here: http://maps.google.com/?ie=UTF8&ll=52.2519...002511&t=h&z=19 Does anyone live nearby
26th Feb, 2008 at 10:16:03am
On 16th Feb, 2008 robert said:
has it ever run ok with the present setup? No, Its another fuel tank, pump and piping than the metro. |
26th Feb, 2008 at 10:42:32am
Edited by Bat on 26th Feb, 2008. VEMs Authorised Installer / Re-seller. K head kits now available!
26th Feb, 2008 at 10:47:33am
Are you using a dizzy with one of those modules on the side?? 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
3rd Apr, 2008 at 09:13:27am
Hey, just wanted to close this topic with our solution. We went over everything once more, and found out that when the carb vent valve is not fitted, you need to close the tube it would normally be fitted to.
Edited by Roger-Wilco on 3rd Apr, 2008. |
