| Home > Help Needed / General Tech Chat > Wetter water on charge cooler? | |||||||
18th Feb, 2008 at 12:41:24pm
Just got chatting over the weekend about ways of making the charge cooler setup as efficient as possible and the suggestion of that "wetter water" I think VW seem to use alot came up.
18th Feb, 2008 at 01:02:11pm
use antifreeze matty, cold weather is indescriminant, it wont treat your charge cooler any differently to your coolant system...plus its reduces corrosion
![]() 966 Posts Member #: 358 Post Whore Snetterton, Norfolk |
18th Feb, 2008 at 01:13:01pm
I know that most high end race cars, i.e. GP2 run entire cooling systems of the stuff. I would personally run a lot of antifreeze as i know how much water wetter costs! You just want the best liquid for a thermal transfer, how about liquid co2 or something? Lotus used to use a refrigerant which looks very similar to a a/c liquid/gas.
18th Feb, 2008 at 02:19:06pm
We have used water wetter in the hillclimber to good effect. It definitely made the car run cooler. I would recommend it. http://www.twin-turbo.co.uk
18th Feb, 2008 at 02:34:07pm
i know Dan used this stuff in his R5 and it kept it a chunk cooler, thats the long and short.
18th Feb, 2008 at 02:42:48pm
Hmmm sounds like it could be worth while then!!
18th Feb, 2008 at 03:03:28pm
not sure mate, but water wetter is cheap enough, well about £15 for a bottle that does the cooling system. |
18th Feb, 2008 at 03:05:15pm
The basic function of water wetter (or similar) is to reduce the surface tension of the water, thus improving the heat transfer.
19th Feb, 2008 at 09:06:18am
fairy liquid :)
19th Feb, 2008 at 03:54:19pm
Lol..I have heard detergent has the same effect with regards to reducing surface tension but I could imagine it would be quite abrasive too! https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
19th Feb, 2008 at 04:07:06pm
Fairy liquid (or detergent) in theory would work, but for two important facts (I know it was suggested in jest):
19th Feb, 2008 at 04:23:41pm
Lol hadn't thought of the bubbles! https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
19th Feb, 2008 at 10:24:56pm
