Home > General Chat > crank sensor
mintymark
Member #: 2039
Blackpool
Is this the crank sensor from KAD
Crank speed sensor mounting kit
Kit of parts to mount crank speed sensor and trigger wheel to the A series engine.
The kit is designed to mount a 122.5mm diameter Ford pattern 36-1 trigger wheel to AHU1878 or Poly V type crank damper via a mounting hub secured by the crank bolt. The sensor bracket bolts to the existing bolts on the cylinder block through the timing chain cover. Infinite trigger wheel adjustment position and fine adjustment of crank sensor. Crank sensor is variable reluctance electromagnetic type, with two pin minitimer type connector.
That's the fella.
