Home > Help Needed / General Tech Chat > Another leak.
Markie_D
Member #: 1660
Formally Mini_Uk
London
Hi lads,
Been away for a while.
Soon as i come back, i noticed another oil leak :(
It's coming between the 2 plates.
Ive used a gasket of course. and also used wellseal.
Why do you think this has happend.
Also, should i use a different gasket sealent ?
Cheers lads.
Shit Happen's
wellseal normally does the trick
have you been round and checked all the bolts are tight?
Markie_D
Member #: 1660
Formally Mini_Uk
London
I tightend the bolts more, hoping it would sort it.
Went for a drive, and still leaking.
Hmmm bugger thing.
Cant understand why ?
Guess ill have to take it apart.. :(
Shit Happen's
Jason G
Member #: 1459
En-suite user
Braintree, Essex
best to start from scratch. Unbolt everything, clean...and bolt back up.
On 19th Jan, 2010 wil_h said:
My guess is that its from the half moon seal between the engine and gearbox
These always leak especially if you have used that crappy one supplied with the gasket set and.... not trimmed it
i always use silicone here with the seal trimmed
Agree with Steve...did you trim the hal moon seal down before fitting?
In the past ive always used RTV sealant on this (without problems) but decided to try wellseal this time as ive heard its good stuff, hopefully all will be good!?
Markie_D
Member #: 1660
Formally Mini_Uk
London
Hi steve,
I used the hard one from minispares.
If it is that, what shall i do to sort it, with out taking the engine block away from the gearbox ?
Cheers :)
Shit Happen's
Ive never done it but..if you take the timing back plate off then you may be able get the old half moon seal out and put a new one in? *oh well*
Its worth double checking what is exactly leaking before attempting to remove this because if you can't swap it over like I just described then its engine out jobby!
Markie_D
Member #: 1660
Formally Mini_Uk
London
Hmm,
Didn't know about trimming it *surprised*
Bugger.
As im doing this at my mums place in kent, taking the engine out is a no no. as ive been there long enough now.
I used well seal on the hard half moon seal. thought it be fine etc. but didn't trim it.
Anyway, what could i do now :(
Cheers..
Shit Happen's
This may be of some use?
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=135792
Markie_D
Member #: 1660
Formally Mini_Uk
London
Hmm bollocks lol Im fcked if it is the half moon seal :(
As i wont be able to take the engine out at my mums place, her bloke will have a baby *evil*.
Shit, bloody, bollocks, cock, wanker, lol.
Where was i meant to trim it from. has anyone got any pictures? would placing silicone round the outside edge seal it till maybe i come across someone who will lend me there garage :)
Cant belive this. thought that was sorted..
P.s, im gonna ask if i could sort it out at there's.
should not take to long to do.
But please give me tips on what i should do to keep it sealed chears :)
Edited by Markie_D on 24th Feb, 2008.
Shit Happen's
Markie_D
Member #: 1660
Formally Mini_Uk
London
If it isn't the half moon seal, what else could it be.
Ill have to check next week when im not to busy.
So u used silicone and not sealant than steve ?
Shit Happen's
if you used the seal i suggested the stiffer one there is NO! need to trim it and you have used sealent in this area
i doubt it will be from there
clean the area and run the engine to determine if its from there
first job dont panic!!!
chriszxr750
Member #: 2138
dartford
where abouts are you i might beable to help?
Markie_D
Member #: 1660
Formally Mini_Uk
London
Where else could it be coming from ?
Ill have to take the cam off to see i guess lol
Shit Happen's
Markie_D
Member #: 1660
Formally Mini_Uk
London
Ive got the car in kent mate.
Thanks for the help though. but me brother's gonna give us a hand.
Cheers anyway mate :)
Shit Happen's
chriszxr750
Member #: 2138
dartford
hey not a problem. just wondered thats all.
good luck though
Shoot youve scared me now
I usually trim that seal, but i cant remember if i did it this time round
Eek, only one way to find out, 2 years of leak free mini-ing may be about to come to a dramatic end
Carl
Member #: 95
liverpool-on-sea
have you used the correct backplate to block gasket i used the wrong one omce and it pissed out. the difference was the shape around the bolt for the alternator bracket slightly different shape but enough to leak when you get a gasket kit they sometimes come with both types and theres not much difference with a quick glance
Edited by Carl on 24th Feb, 2008.
hughesmarkie
Member #: 1197
Dublin Ireland
Ive the same leak (half moon) on my 1430 clubby, so its engine out for me..*frown*
Thats 2 minis off the road in 6weeks... with me rebuilding the turbo at the moment, bloody minis LOL
Markie_D
Member #: 1660
Formally Mini_Uk
London
You know what, i bloody hope it's that *tongue* coz if it is the half moon,(be shocked if it is) then im gonna blow it up *laughing* coz i looked under the car, and noticed my gay brother put the clevis pins in thick end first *surprised* as the tapered pins.
will that be a problem ?
I see there is 2 gaskets in th kit.
Black and light bluie colour.
which one do i use ?
http://www.minispares.com/Product.aspx?pid=36081
Cheers..
Shit Happen's
Carl
Member #: 95
liverpool-on-sea
i think the a+ one is the blue one. could somebody else please confirm. pretty sure it is.
and what clevis pins are you onabout?
Markie_D
Member #: 1660
Formally Mini_Uk
London
Sorry not the clevis pin. the pin that holds the gearbox rod change onto the other rod part coming out of the gearbox.
cant remeber the name of the pin ? im crap at remebering names.
They have been put on wrong way round, as there tapperd pins.
so if i have to take the engine out, which i hope i dont.
then its gonna be harder to get out..
Cheers.
Shit Happen's
Roll pin is the word on the street...lol
Whack it in reverse and it puts it in a nice angle to get a punch on it to knock it out. *wink*
They are parallel so should knock out both ways.
Markie_D
Member #: 1660
Formally Mini_Uk
London
Roll pin's the name then *tongue* thanks for that matty.
I thought they were tapperd. well glad it should be ok to get out then, if thats the case.. hope not *crying*
Ill let you know what it is thats leaking when i get round to sorting it out this week or next.
Yeah, if someone could comfirm what gasket it is also.
Blueie coloured one, or black.
Thanks alot.
Shit Happen's
