| Home > Help Needed / General Tech Chat > Coil wiring / 2 wire dizzy / No spark | |||||||
150 Posts Member #: 1591 Advanced Member Prudhoe, Newcastle |
4th Mar, 2008 at 06:34:17am
Hello
4th Mar, 2008 at 09:09:49am
4th Mar, 2008 at 09:50:14am
yup, that is a mk1 dizzy and needs the seperate module. |
![]() 53 Posts Member #: 1675 Advanced Member |
4th Mar, 2008 at 11:48:57am
we dont even have a spark from the coil at the minute |
19 Posts Member #: 480 Member |
4th Mar, 2008 at 12:14:08pm
Right, i can get another dizzy so thats fine.
Edited by Jordie on 4th Mar, 2008. |
4th Mar, 2008 at 12:47:40pm
how you going to get a spark from the coil without a dizzy? |
4th Mar, 2008 at 12:50:30pm
Should the coil not provide a spark from the lead that goes into the centre pin of the dizzy?
194 Posts Member #: 1297 Advanced Member Sunny Stockport |
4th Mar, 2008 at 12:59:17pm
The solid white wire is the 12v feed to the coil, should go onto the coil + terminal. The double white / black wire goes onto the - terminal on the coil and the single white / black wire a bit further down the loom goes to the dizzy (a 1979 Mini had points so only 1 wire). If your other dizzy you mention has points and the coil is the electronic ign type, beware as you'll need a ballast resistor.
4th Mar, 2008 at 01:45:33pm
if you think of an old points system, its the condensor drawing the spark, i assume thats the same job as what the amplifier does. otherwise there would be no spark control as the coil would spark all the time.
4th Mar, 2008 at 05:49:10pm
4th Mar, 2008 at 06:13:28pm
we put a direct 12v feed to it from the solenoid, and a direct feed to ground too, yet still no spark.
4th Mar, 2008 at 06:36:29pm
Getting a different dizzy tomorrow, which is standard mg metro turbo. so will connect it all up. check with multimeter and go from there.
the coil is definately a worker too as it was running a different engine a couple weeks back...
