| Home > For Sale > Ring gear style triggerwheels | |||||||
![]() 265 Posts Member #: 68 Senior Member Coventry |
13th Mar, 2008 at 09:23:41am
got a few of these up for grabs if anyones interested. you need to get your pulley machined to suit, but easy at any machine shop. ID is 100mm & OD is 130mm. mounting like this alows fine tuning of position in relation to your trigger.
Sooperdooperturbocooperexpertengineering! |
13th Mar, 2008 at 09:28:50am
13th Mar, 2008 at 10:12:43am
Could be a possibility.. would need to know some sizes. what do MPI pulleys lok like? where would these ring gears fit?
13th Mar, 2008 at 06:19:17pm
How thick is it ???
13th Mar, 2008 at 07:59:17pm
its 5mm thick, and i had 4.5mm depth taken off pulley, this gives 0.5mm step for cap heads to grip
![]() 3756 Posts Member #: 1709 I like granny porn. LONDONSHIRE |
13th Mar, 2008 at 08:24:08pm
i have the same setup, but i welded mine on. On 2nd Oct, 2009 Vegard said:
I bet my first wank came quicker than your first mini turbo These new modern turbos with their quick spool up time, would make the competition harder. On 15th Aug, 2011 robert said:
phew!!! thank you brett for smashing in my back doors .( not something i imagined writing... EVER) |
13th Mar, 2008 at 09:12:37pm
thats always an option... but maybe not as adjustable!!! LOL... and if you are like me, the more adjustment the better!! ha ha. Sooperdooperturbocooperexpertengineering! |
![]() 168 Posts Member #: 1772 Advanced Member Leicestersheershire |
14th Mar, 2008 at 04:51:36pm
Got mine today. Cheers. Tim Rowe
14th Mar, 2008 at 05:59:19pm
On 13th Mar, 2008 rubicon said:
i have the same setup, but i welded mine on. and it seems i did it inthe wrong position!! so mybe i should have gone for the latter.... On 2nd Oct, 2009 Vegard said:
14th Mar, 2008 at 06:01:38pm
If you are out by 90 degrees can't you swap the leads over until you get the pulley sorted out? Tim Rowe
14th Mar, 2008 at 06:06:32pm
i think il just whip it of and remove/replace the missing tooth,
14th Mar, 2008 at 06:57:34pm
Sounds sensible. Just make sure that you cut the right tooth. Tim Rowe
14th Mar, 2008 at 07:33:19pm
or file a fresh keyway. On 28th Aug, 2011 Kean said:
15th Mar, 2008 at 11:20:56am
Thanks Ross,
20 Posts Member #: 1706 Member WILTSHIRE |
15th Mar, 2008 at 01:31:42pm
I'd like one please, PM sent. |
17th Mar, 2008 at 12:48:51pm
Retired - No probs, Thank you!
18th Jul, 2008 at 10:14:23pm
got some more of these if anyone's interested?
![]() 1840 Posts Member #: 54 Post Whore nr coventry |
20th Jul, 2008 at 04:11:34pm
PM your details i'll have one! i'm in coventry SKYLINES ARE LIKE CLITS, EVERY FLANGE SEEMS TO HAVE ONE: see this sticker on my silvia
20th Jul, 2008 at 05:05:30pm
PM sent, I'll take another if the size is identical to the earlier ones. Schrödinger's cat - so which one am I ??? |
20th Jul, 2008 at 05:31:49pm
retired : Yep same as before, PM Sent.
Edited by mini-marauder on 20th Jul, 2008. Sooperdooperturbocooperexpertengineering! |
20th Jul, 2008 at 05:32:13pm
retired : Yep, same as before, PM Sent.
20th Jul, 2008 at 06:11:23pm
me pm sent again lol SKYLINES ARE LIKE CLITS, EVERY FLANGE SEEMS TO HAVE ONE: see this sticker on my silvia
329 Posts Member #: 3193 Senior Member Torbay, Devon |
23rd Jul, 2008 at 07:16:00pm
23rd Jul, 2008 at 10:38:39pm
Hopefully the following pics will help out with that.
Edited by mini-marauder on 23rd Jul, 2008. Sooperdooperturbocooperexpertengineering! |
24th Jul, 2008 at 07:27:28am
In which case I would like to order one of these please!
P
