| Home > Help Needed / General Tech Chat > Guidance with actuator please | |||||||
![]() 214 Posts Member #: 1574 Senior Member Malta |
13th Mar, 2008 at 07:32:48pm
I am puzzled at why the original metty set up had a 'Tee' on the compressor housing. I think one side went to actuator and the other to the ECU (see below):
13th Mar, 2008 at 08:08:59pm
I am fitting a manual bleed valve. Does the hose that went to the ECU go to the bleed valve and routeback to... Where? Leaving the actuator feed like this:
Or do I blank one side of the 'Tee' and break the feed to the actuator with the bleed vlave? |
13th Mar, 2008 at 08:25:05pm
13th Mar, 2008 at 08:41:45pm
Was I correct that the 'other side of the tee fed the ECU in the metty originally?
13th Mar, 2008 at 08:45:33pm
Yep thats correct! |
13th Mar, 2008 at 08:51:43pm
Thanks for your help gents
13th Mar, 2008 at 10:07:05pm
Happy Birthday, by the way.
14th Mar, 2008 at 12:42:19pm
Thanks Paul!!
