Home > Help Needed / General Tech Chat > radiator mounting
Carl
Member #: 95
liverpool-on-sea
must be sick of rad questions by now, lol.
anyhow how many people have solid mounted there front rads and have they been ok ive used exhaust bobbins in mne and it wobbles alot.
cheers
Nick
Member #: 154
Midlands
thats a lot better than mines mounted then dude. all i did was drill 2 holes in the subby for the pegs on the bottom to sit in, the hoses hold it in place well enough for me :)
I saw a Miglia / Seven esc car at Malvern today that had the rad mounted exactly the same way.
I've gone one step further and made a sort of slam panel for mine, no idea if it will work or not mind.
http://www.putfile.com/pic/7823719
Edited by Rob H on 16th Mar, 2008.
Rubber mount is best as rads get shaken apart by vibration.
Mines solid to an extent. The metal tubes on the bottom of the rad just slot into steel plates. The hoses then hold the top so give plenty of give.
They're a clearance hole in the bottom so can move.
Just read, same as Bud *smiley*
Star Mag
Member #: 375
Leicestershire
Mine is done the same as Rob h, not had any problems just drilled the subframe and have a plate on the top to hold it down!
