| Home > Help Needed / General Tech Chat > dieting! | |||||||
78 Posts Member #: 2322 Advanced Member rednal birmingham |
16th Mar, 2008 at 01:31:27pm
i want to remove the rear bins, but does it reduce the structure of the shell? i'm trying to lose weight! (to the shell). YOU CANT POLISH A TURD, BUT, YOU CAN ROLL IT IN GLITTER!!!! |
16th Mar, 2008 at 02:27:58pm
mine are gone and nothing has gone wibbly |
16th Mar, 2008 at 05:32:27pm
Most people would say that every part of the mini is structural, and helps with rigidity.
In the 13's at last!.. Just |
16th Mar, 2008 at 10:06:04pm
17th Mar, 2008 at 09:55:29am
I've removed mine but had to add additional plating to the B post and sill as Bat pointed out to join the 2 together. |
17th Mar, 2008 at 09:59:38am
I thought this was going to be about weight watchers. I've lost 11lbs yay! On 7th Nov, 2008 Nic said:
17th Mar, 2008 at 04:58:21pm
i would leave them IMHO
17th Mar, 2008 at 06:07:18pm
mine is getting a full cage tied to the shell so i should be alright i think |
17th Mar, 2008 at 08:29:28pm
well, thanx guys! stuff it, they're coming out! and if i dont think its safe, i'll cage it! YOU CANT POLISH A TURD, BUT, YOU CAN ROLL IT IN GLITTER!!!! |
![]() 1840 Posts Member #: 54 Post Whore nr coventry |
18th Mar, 2008 at 12:46:57pm
as others have said, if youtake them out weld a little plate to tie the b-post to the sill, i ran my mini with the bins & seatpan cout out for two weeks with no cage & it did feel like a little stiffness was lost, put a 6-point cage in & its was betterthan standard,
18th Mar, 2008 at 01:33:50pm
any bit of metal you cut out will reduce the strenght of the car. many here have fitted flip fronts, cut the rear bins out and even the rear seat.
![]() 2102 Posts Member #: 432 Post Whore Swindon |
18th Mar, 2008 at 02:25:37pm
if your taking them out, any chance you could de them really carefully? I want mine back lol |
18th Mar, 2008 at 08:55:43pm
oh poo!:- didnt think that it would make that much of a difference to be fair, but if it made clubminiflip's a bit dodge, then i'll fit a cage and then take them out, thanx all for your response YOU CANT POLISH A TURD, BUT, YOU CAN ROLL IT IN GLITTER!!!! |
18th Mar, 2008 at 09:14:06pm
there are pics of mine in my thread in the "show me yours bit!
19th Mar, 2008 at 09:14:54am
i cant answer 100% but i would say no....
