| Home > Help Needed / General Tech Chat > boost controller fitment?? | |||||||
34 Posts Member #: 2156 Member wigan jnt 23 m6 |
18th Mar, 2008 at 08:26:58pm
me thick me |
18th Mar, 2008 at 08:55:17pm
i always thought that they just went out of the compressor housing into the controller and the out of the controller into the actuator....not sure now ive seen the T-peice though.
18th Mar, 2008 at 09:00:57pm
i know thats whats throwing me !! andy |
2646 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
18th Mar, 2008 at 09:39:28pm
I think the t piece goes inline with the actuator, then off the t into the inlet of the mbc, think the outlet goes to atmosphere, believe the idea is it will run the boost that the actuator is set untill the boost overcome the spring pressure in mbc (ajustable)
19th Mar, 2008 at 12:11:25am
on these things, the "t-piece" bit goes between the turbo and actuator, arrow pointing towards the actuator. the other nipple whih isnt screwed into the t-piece gets plumbed to the bottom barb on the "boost controller" bit. the top barb is left open to atmosphere.
19th Mar, 2008 at 12:13:03am
and shane your kinda right, on these things the ball and spring is in the "t-piece" and the screwy bit act as a normal bleed screw. there an odd setup but they do work. turbo 16v k-series 11.9@118.9 :)
19th Mar, 2008 at 08:54:25am
cheers fellas andy |
19th Mar, 2008 at 10:38:01am
i had to remove the ball and spring from the T peice so that i could get boost in second gear. |
1st Apr, 2008 at 11:50:29pm
On 19th Mar, 2008 evolotion said:
and shane your kinda right, on these things the ball and spring is in the "t-piece" and the screwy bit act as a normal bleed screw. there an odd setup but they do work. |
2nd Apr, 2008 at 08:17:24pm
Right, ive been trying to get my headround this this eve, but to joy. with the pressure connected to the actuator alone it is fully open at 8psi, once the t piece is installed (as in the pic) and the anodised outlet blocked the actuator wont open below 12psi, this is a sod for me as I was planning to run 6psi on the actuator and use the solenoid and mbc to bleed off to 12 via the MJ. Is how I have it piped correctly? and how can I get the actuator to open at 6 psi?
2nd Apr, 2008 at 10:39:28pm
2nd Apr, 2008 at 10:52:54pm
Cheers Gav, will try that, (when the parts im waiting for turn up)
![]() 233 Posts Member #: 863 Senior Member Lathom, lancs |
1st Nov, 2008 at 01:08:25am
This has reeealy confused me, so the T goes in between the actuator and what? (where does the actuator pipe go to if i didnt have one of these fitted, isent it to the clock to show what psi its running? )
Edited by MINIMON on 1st Nov, 2008. |
1st Nov, 2008 at 07:42:49pm
It really does not matter whether the solenoid is before or after the boost controller.As already been said,set the minimum boost by the pre load on the actuator -it wont go below the level provided by the spring in the actuator -and then set the higher boost level by experimenting with the amount of bleed you set.The picture you show has it set up OK.Mini mon the tee goes in the line from the compressor housing to the actuator.I wouild connect the boost guage to a tapping in the manifold so that you are actually measuring manifold pressure, which may not be the same as the pressure at the compressor housing.Shane has already said most of this above. |
ive never fitted on of thease i guess that the T piese goes inline with the actuator then goes to the controller then theres an outlet were does this go please
andy
