Home > Help Needed / General Tech Chat > excess crank endfloat on stripdown
Helped a friend take out and strip down his very tired 1275 A series tonight (unknown mileage/history) for a cheap rebuild, got as far as taking the flywheel off, but its proving it be a very tight one, so gave up on it for tonight.
We noticed when putting the puller on that there is loads (about 5 or 6mm) of give in the crank.
What do you guys think this will be? could the thrusts just be really worn? or dropped out?
It ran before we took it out, but sounded extremely poorly. My mates gutted now, as his cheap rebuild plans might be out the window, and not only that he thinks the engine might be fecked.
I feel a bit bad, as I kind of convinced him to start down this path...
Whats the worse endfloat you guys have had in the past?
Joe
Jason G
Member #: 1459
En-suite user
Braintree, Essex
That kind of give...has it got thrusts in it?
Edited by Jason G on 20th Mar, 2008.
On 19th Jan, 2010 wil_h said:
sounds like the thrusts have fallen out - seen this once before. The crank ended up machining itself against the centre main cap.
As for feeling bad, if the engine had this amount of end float, I don't think there would have been any choice soon
As you measure end float in thou, if you can see play in mm it's fubar'd :(
expect something drastic ....sorry to say
well, bit of an update, the flywheel proved very (very very) stubborn, so the engines just been sat till last night used my new hydraullic puller and was exceedingly smug when it popped off after just a few turns :)
bad news is it is the thrusts that had dropped out, found 1 intact in the bottom of the box, another one a little mangled etc so worse case scenario
the crank is fecked, but the block doesnt appear to be that bad, and might be reusable, ill get some pics up for your opinions soon
the thrusts that we have found dont look very worn though?
why would they fall out of the centre main?
dont want to put it all back together and find it drops them again...
cheers
joe
