| Home > Help Needed / General Tech Chat > No spark (megajolt) | |||||||
21st Mar, 2008 at 01:21:32pm
I have wired up my megajolt and edis unit. I have turned the engine over and would not start. I am not getting a spark to the plugs. I have a 12v to the megajolt. what do i need to check to see if i am getting a live to the coil pack and then out again?? |
21st Mar, 2008 at 01:35:45pm
Pin 2 of the coil should have 12v power, but if there is no spark I would start at the VR sensor.. did you get it wired up the correct way round? one way works the other doesn't and its difficult to tell which is correct, most peeps end up trying it both ways until it works! website:- http://www.terryhunt.co.uk
21st Mar, 2008 at 05:10:53pm
21st Mar, 2008 at 06:52:38pm
yes have power to the coil pack, had a spark when unpluged the mj then nothing. will try changing round the vr sensor. tomorrow is a new day with new challenges. |
21st Mar, 2008 at 10:55:02pm
does it run just on the EDIS?
AlexF |
22nd Mar, 2008 at 12:13:55pm
On 21st Mar, 2008 Turbo Tel said:
Pin 2 of the coil should have 12v power, but if there is no spark I would start at the VR sensor.. did you get it wired up the correct way round? one way works the other doesn't and its difficult to tell which is correct, most peeps end up trying it both ways until it works! you were right i have the vr sensor wires the wrong way round, now it is running just on the edis unit. now to sort the mj out he says chuckling to himself |
22nd Mar, 2008 at 07:01:30pm
On 21st Mar, 2008 AlexF2003 said:
does it run just on the EDIS? If not make it run on that 1st before you get the MJ on there. Alex Mine wont run just on the edis, wont even start up, i had to mess with the tuning first. Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
