| Home > Help Needed / General Tech Chat > Carb gasket question? | |||||||
455 Posts Member #: 1502 Senior Member Aberdeenshire, scotland. |
22nd Mar, 2008 at 11:27:58pm
Just finished rebuilding my carb and im about to bolt the plenum back on and the carb to the manifold. However, the brown gaskets in the piccy below, the diameter of the hole is too small, am i meant to tear out the perforated bit so that its bigger? And where do these two gaskets go?
22nd Mar, 2008 at 11:32:07pm
Yes I think you will need the bigger hole, I din't fancy them ones so bought proper sized gaskets instead.. Easy when my best mate owns a parts store!!
23rd Mar, 2008 at 12:56:16am
Cheers, just needed to double check.
444 Posts Member #: 2885 Senior Member |
12th Feb, 2009 at 12:12:13am
*Outlet for the 'dump valve' lol. |
12th Feb, 2009 at 08:49:20am
If you have the cable bracket and a spacer then you would have needed 3 of those gaskets I assume? |
45 Posts Member #: 8924 Member New Zealand |
25th May, 2010 at 02:43:38pm
looks like the wrong gaskets to me... NEW ZEALAND MIGLIA SPEC ROAD LEGAL TURBO MINI BUILD THREAD >>>
25th May, 2010 at 03:01:05pm
I've got a set of the ones from the metro turbo set. DK451?
In the 13's at last!.. Just |
