Home > Help Needed / General Tech Chat > Pre verto clutch plunger and release bearing
shane
Member #: 1246
Lowestoft, Suffolk.
Just managed to dig out a wok with pre verto arm etc, removed the plunger but am unsure if its correct, also the release bearing looks like a verto. What do you think?
Shane
Jordan
Member #: 1392
Pointless Post Whore
Liverpool, North west
Looks like a verto bearing to me.
I'd say it was pre verto from the pics.
The verto bearing is usually smaller in diameter.
Jordan
Member #: 1392
You can tell by the length of the spiggot on which the bearing sits
A long spiggot is pre verto and shortish one is verto. That one looks quite short i thought
shane
Member #: 1246
Lowestoft, Suffolk.
I thought it looked the same as the verto bearing, im now headed over to te workshop so will take a camera and get some better pics.
Shane
shane
Member #: 1246
Lowestoft, Suffolk.
Took a verto wok with me to compare, and the plunger and bearing look the same, what do you think? Would the clutch of opperated with a pre verto arm on a verto plunger? No idea if the engine it came off was running this wok with a verto or pre set up under it?
Shane
Better pic of the one im trying to identify
Verto wok
Verto release bearing
Both side by side.
Edited by shane on 24th Mar, 2008.
Coupe
Member #: 2178
Leyland, Lancs
Thats a verto - looks identical to the one I took out of my wok to replace with my pre-verto setup.
