| Home > Help Needed / General Tech Chat > oil pressure | |||||||
![]() 862 Posts Member #: 1660 Formally Mini_Uk London |
26th Mar, 2008 at 01:49:27pm
Hi all.
Shit Happen's |
26th Mar, 2008 at 01:55:34pm
Sounds about right to me, if thats from cold? https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
26th Mar, 2008 at 01:56:40pm
i assume he means when the engine isnt running.
26th Mar, 2008 at 01:59:29pm
Lol gotcha. Thats the exact reason ive stcuk with the simple hydraulic gauge..you know where you stand! https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
26th Mar, 2008 at 02:39:59pm
yeah i'm a fan of mechanical gauges! only need to light them up then! |
26th Mar, 2008 at 04:01:27pm
Ive checked all the wires and connetions, which all seem ok.
Shit Happen's |
26th Mar, 2008 at 04:07:44pm
Any pics of the rear of that gauge?
26th Mar, 2008 at 04:54:49pm
Connect the wire direct to ground and see if the gauge reads zero? https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
26th Mar, 2008 at 05:45:11pm
does it work properly with the engine running?
AlexF |
26th Mar, 2008 at 06:43:00pm
On 26th Mar, 2008 Tom Fenton said:
Any pics of the rear of that gauge? For it to go straight to 100 without the engine there must be a wiring fault somewhere. I have this diagram. but if u want a real picture, i can take one tomorow ?
On 26th Mar, 2008 matty said:
Connect the wire direct to ground and see if the gauge reads zero? Tried that mate, but didn't go to zero. like i said, it was working fine before. could it be a fcked wire ? On 26th Mar, 2008 AlexF2003 said:
does it work properly with the engine running? I have seen oil pressure gauges do that before. Alex No mate, still stays at 100. Cheers. Shit Happen's |
110 Posts Member #: 1657 Advanced Member wirral |
26th Mar, 2008 at 07:41:19pm
could be an internal fault with the gauge itself? or your sender is fubared. On 15th of Apr, 2007 at 09:08pm Vegard said:
What the fuck is that on the rear of the car? One of the most stupid things I've ever seen. Rest looks nice. 10.5 psi no idea how many banannas |
26th Mar, 2008 at 08:28:43pm
26th Mar, 2008 at 08:31:31pm
As long as the thing worked fine before....disconnect the wire at the sender, If it goes to 0 the sender is fooked. if it stays at 100 the gauge is fooked.
Edited by Turbo Tel on 26th Mar, 2008. website:- http://www.terryhunt.co.uk
27th Mar, 2008 at 10:13:00pm
Had a mate come round, and turns out to be the sender.
Shit Happen's |
28th Mar, 2008 at 12:14:10am
30th Mar, 2008 at 04:50:03pm
On 27th Mar, 2008 Mini_Uk said:
Had a mate come round, and turns out to be the sender. Cheers Sturgeo has just fitted one of these gauges and has exactly the same problem. Goes to full scale when the ignition is turned on. What was wrong with your sender? Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
30th Mar, 2008 at 07:09:00pm
i'm guessing it was broken |
30th Mar, 2008 at 07:47:55pm
Had a mate come round, and turns out to be the sender. Cheers Sturgeo has just fitted one of these gauges and has exactly the same problem. Goes to full scale when the ignition is turned on. What was wrong with your sender? Not sure mate, just broken i guess
I just changed mine, now it works great. :) Shit Happen's |
455 Posts Member #: 1502 Senior Member Aberdeenshire, scotland. |
30th Mar, 2008 at 07:48:39pm
Iv got that gauge too. Hope it works when i got to put it in.lol
30th Mar, 2008 at 07:53:37pm
On 30th Mar, 2008 hammoj28turbo said:
Iv got that gauge too. Hope it works when i got to put it in.lol Mine was working fine. till one day i noticed it was at 100. Good luck mate :) Shit Happen's |
30th Mar, 2008 at 08:22:41pm
Thanks.
857 Posts Member #: 1778 Post Whore Northants |
1st Apr, 2008 at 10:37:34am
Well i've fixed it :)
1st Apr, 2008 at 12:24:28pm
On 1st Apr, 2008 sturgeo said:
Well i've fixed it :) My pressure sender had 2 terminals on, one for the connection to the gauge and another for a "optional" earth. Turns out both the gauge and the sender need to be earthed to the same point. Thats right. glad you sorted it mate. What's your pressure reading by the way ? Cheers Shit Happen's |
1st Apr, 2008 at 02:18:24pm
Well i've only started it up to to test the gauge so the engine was cold and it was reading 60 psi at idle. |
