Home > General Chat > Powder Coating Wheels
Anton
Member #: 764
Staffordshire
Im trying to get a set of steel weller wheels powder coated...
The place my dad works can get them done for the price of a couple of pints. But having spoken to a local wheel re-furb place (i was after someone to shot blast em first) they say that normal powder coating doesn't work too well on wheels and they do a "proper job" of it?
Anyone know anything about it?
If the local wheel place was Lap-tab don't bother, they look nice at first but as soon as you need new tyres the clear lacquer comes off in big sheets. From personal experience of my own and my best mates wheels.
Well as it's steel wheels you're getting PC'd anywhere the PCs steel should be able to do the job.
I'd heard though that 2pac paint is less likely to flake due to chips etc than PC?
jamesfawcett
Member #: 218
Bingley, West Yorkshire
is there a percentage involved when getting them powdercoated or something too, i seem to remember 30% laquer on mine to keep a matt black look. Mine cost a fortune to have done i went to the best possible place with loads of experience, and they are still as good as when i had them done.
MarkGTT
Member #: 1194
Shropshire.
where do you reccomend then Tom? i was just about to use them.. and they arent cheap!
I don't know TBH, I spent a lot of money getting a set of wheels done there, admittedly they looked fantastic for about 12 months, but as soon as I had to have tyres changed the lacquer started coming off in big sheets. A mate of mine also had the same thing happen.
Since then I've painted any wheels I want painting myself with 2k paint and lacquer.
the place i got my wheels from doesn't recommend powder coat and prefers 2-pack
clubminiflip
Member #: 54
nr coventry
i've used lap-tab, they used to do my rims for 20 a wheel need a few sets doing myself in the midlands, i've been advised 2pac, if i could find somewhere to blast my rimscheap then i'd paint them 2pac myself due to having the kit!
any recommendations for wheel blasting in the midlands
Lance Link
Member #: 1174
Sunny Southern California, USA
The laquer peeling thing sounds odd to me. Powdercoat is a final finish. Why would they paint a laquer finish over a baked on powdercoat? It shouldn't need a clear coat over it unless you are trying to achieve some sort of finish effect.
Are you sure they really powdercoated them and they didn't just quickly paint them and charge powdercoat $$? Powdercoat is many time harder than a painted finish. As a result, it should hold up in situations where paint would peel and chip.
61 Austin Seven; building a 1275 'over the clutch' turbo, R5 T2'd, custom intercooled, megajolt electrified, canyon carver
www.motorlust.com - The Online Magazine for Car Guys Like Us
Laptab apparently stove enamel the wheels. They look great for a while but then the lacquer comes off.
Alex1340
Member #: 111
Loughborough
powder coating will be much stronger than paint, the wheels must be stripped and chemically cleaned then etched primerd before coating, once baked will be hard as nails. I had my alloys on my mazda done by some guys we sell equipment to and there still perfect. definatly should be NO lacquer on PC wheels. Pristine alloy wheels do a good job but there Northampton way. to be geeky they use a Gama optiflex unit. very good stuff.
