| Home > Help Needed / General Tech Chat > Stuck clutch. | |||||||
![]() 862 Posts Member #: 1660 Formally Mini_Uk London |
27th Mar, 2008 at 10:20:53pm
Got the car running ok.
Shit Happen's |
27th Mar, 2008 at 10:23:20pm
are you running a carpet? sometimes my big adjusting nut winds undone and the pedal gets stuck on the U bolts for the steering rack |
27th Mar, 2008 at 10:23:37pm
it will be partially siezed between the clutch arm where it goes into the cover
998 Posts Member #: 2178 Post Whore Leyland, Lancs |
27th Mar, 2008 at 10:24:31pm
I've had that happen before, but only when I've left a car standing for a long time without use - the clutch plunger just got stuck in the wok. Did you grease up the plunger, arm, pushrod etc...? On 15th Jul, 2009 fastcarl said:
a breif struggle ensued but Will emerged the victor with a pair of undies in his possesion On 21st Sep, 2009 apbellamy said:
No, but you did chuck your guts up over my front gate the Saturday before! You even managed to get a bit in your arm pit... |
27th Mar, 2008 at 10:31:56pm
Yep i greased it all up..
Shit Happen's |
27th Mar, 2008 at 10:48:22pm
oil it
27th Mar, 2008 at 10:59:43pm
On 27th Mar, 2008 BENROSS said:
oil it
told you the head would grenade your arse ...lol ![]() ![]() Ok, ill use some 2in 1 oil on the plundger. took me mum out in it. she thought it was great lol she said it's like a little racing car, but bit bumpy. lol wished i got the coil damper and springs now. everyone looks round when im coming up the road lol it's funny. they must think, his car sounds fooked lol never mind.
Shit Happen's |
27th Mar, 2008 at 11:19:24pm
have safe fun
28th Mar, 2008 at 07:57:32pm
I found the problem.
Shit Happen's |
28th Mar, 2008 at 07:59:50pm
thats just a dust i think, it shouldnt effect the operation of the clutch to such and extent i wouldnt have though? "Turbo's make torque, and torque makes fun"
28th Mar, 2008 at 08:02:09pm
On 28th Mar, 2008 joeybaby83 said:
thats just a dust i think, it shouldnt effect the operation of the clutch to such and extent i wouldnt have though? Well it did this time. plus i noticed some oil inside the rubber thing, take it thats normal.
Shit Happen's |
28th Mar, 2008 at 08:03:42pm
28th Mar, 2008 at 08:05:34pm
not really, maybe a little grease to lubricate the pin, but if theres a far bit it sounds as though the seal might be leaking fluid?
28th Mar, 2008 at 08:21:51pm
It's a verto clutch..
Shit Happen's |
28th Mar, 2008 at 08:27:45pm
28th Mar, 2008 at 08:32:22pm
Right, I had mine do this, and I think I know what it is now.
29th Mar, 2008 at 07:44:59pm
On 28th Mar, 2008 Coupe said:
Right, I had mine do this, and I think I know what it is now. Have a look at the bracket which the slave cylinder is attached to - I bet the third bolt (the one that goes into the side of the wok, rather than the top of the bell housing) has either come loose, or fallen out and the bracket has bent. This means your slave cylinder is able to push the pushrod further, it comes out at an angle and gets stuck. Take the slave cylinder off, and fix that bracket down properly and all will be hunky dory. Do you mean this where the arrows pointing to ?
Think it needs some washers underneath to rise it up abit, as what you said is true, the pushrod is at an angle and gets stuck
Cheers. Shit Happen's |
29th Mar, 2008 at 11:03:04pm
Yeah, if the pushrod is coming out at an angle, whack a couple of washers under there until its straight. On 15th Jul, 2009 fastcarl said:
