| Home > Help Needed / General Tech Chat > Coil pack mounting. | |||||||
28th Mar, 2008 at 08:44:48pm
I have had a search but couldnt find anything (must be somewhere its just me that carnt find it)
28th Mar, 2008 at 08:48:34pm
28th Mar, 2008 at 08:49:28pm
Mine is on the clutch housing, and no problems yet. The TT2 is mounted on the brace bar and the fiesta leads fit perfectly. http://www.twin-turbo.co.uk
28th Mar, 2008 at 08:49:54pm
I wouldn't! Mine is on an ally bracket with rubber mounts and in use since 1992 which reminds me about time i bought a spare! On 5th Sep, 2011 Vegard said:
28th Mar, 2008 at 10:02:58pm
Thanks, I havent realy anywhere else to put it without having very long leads (not sure if that would be a prob but would of thaught the shorter the better)
348 Posts Member #: 2253 Senior Member Las Vegas, Brit in the States |
28th Mar, 2008 at 10:14:05pm
i have mounted mine on the bulkhead next to the wiper motor. |
28th Mar, 2008 at 11:13:56pm
On 28th Mar, 2008 miniboo said:
i have mounted mine on the bulkhead next to the wiper motor. I carnt, i dont have a bulkhead in mine ? Rick |
28th Mar, 2008 at 11:18:48pm
28th Mar, 2008 at 11:23:57pm
Thanks Gav, Think thats where its going nowhere else tbh
![]() 736 Posts Member #: 1865 Post Whore Norwich, Norfolk |
29th Mar, 2008 at 07:52:06am
I got the fiesta lead set from halfords which are far to long, so i mounted the coil pack, edis etc all inside the car behind the dash (altho i have no dash) makes the engine bay nice and tidy :) |
29th Mar, 2008 at 09:07:06am
Rick I too would avoid engine mounting and I too use zetec leads. Putting a coil on an engine I would think subjects it to too much vibration. Yes it is where the coil sits on a 998 std Min but then coils don't last long on Minis at the best of times. Why not on one of the bracing bars if you have no inner wings? On 5th Sep, 2011 Vegard said:
29th Mar, 2008 at 09:21:12am
29th Mar, 2008 at 09:26:04am
i just thought that bat, theyre on the engine as std so you should be ok |
29th Mar, 2008 at 09:41:52am
as above, on the 1.1 they are bolted to the block. On 28th Aug, 2011 Kean said:
![]() 368 Posts Member #: 806 Senior Member Cirencester, Gloucestershire |
29th Mar, 2008 at 10:11:03am
theyre on the back of the engine on my 1.3 festa aswell
so if it's good enough for Ford?
