| Home > Help Needed / General Tech Chat > OT - Timing Light adapter | |||||||
29th Mar, 2008 at 10:16:35am
I saw somewhere once a device for using a timing light on a wasted spark ignition system.
29th Mar, 2008 at 10:39:26am
29th Mar, 2008 at 11:13:53am
yup i do the same as gavin jim . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
29th Mar, 2008 at 03:40:29pm
On 29th Mar, 2008 Bat said:
Hi, I've not heard of one, I just use my timing light and halve the RPM or Advance degrees. Have you tried Snap On or Britool? Cheers, Gavin :) REAL men use a bog standard timing light with no dials! dials are for fairies. website:- http://www.terryhunt.co.uk
29th Mar, 2008 at 04:46:04pm
Hi, I've not heard of one, I just use my timing light and halve the RPM or Advance degrees. Have you tried Snap On or Britool? Cheers, Gavin :) REAL men use a bog standard timing light with no dials! dials are for fairies. Well. I will disagree with you partly
Timing lights with a dial for advance is a very usefull tool, but i do agree there is no need for the ones that tell you the RPM. On wasted spark systems, You dont have to halve the advance degrees but you do need to halve the RPM . If its EDIS you have to take into consideration the 10 degrees standard advance
29th Mar, 2008 at 05:14:41pm
29th Mar, 2008 at 06:12:27pm
Timing lights with a dial for advance is a very usefull tool, but i do agree there is no need for the ones that tell you the RPM. On wasted spark systems, You dont have to halve the advance degrees but you do need to halve the RPM . If its EDIS you have to take into consideration the 10 degrees standard advance ![]() well i will disagree with you totally !
http://www.autosportlabs.org/viewtopic.php...ighlight=strobe check out this link , its the same prob iv found with my strobe , it reads twice degrees . Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
29th Mar, 2008 at 06:38:03pm
Never used one..
29th Mar, 2008 at 06:49:31pm
29th Mar, 2008 at 07:41:49pm
How can it read twice the degrees when the timing mark is at TDC and each spark happens before TDC, they are not addative?
29th Mar, 2008 at 08:17:25pm
I have to say that from logic I think Sprocket is right.
29th Mar, 2008 at 08:17:56pm
Edited by Bat on 29th Mar, 2008. VEMs Authorised Installer / Re-seller. K head kits now available!
29th Mar, 2008 at 08:21:57pm
29th Mar, 2008 at 09:42:22pm
Hi, I don't know how but it does, either that or I'm running 90 degrees of advance on my Mpi contraption
Thinking about it more, the computer in the timing light has to calculate the advance, the only way it can do that is by reference to the RPM and time elapsed from the first spark, therefore if you put another spark in mid way it will halve the time in the calculation and that will halve the advance in the calculation. therefore you'll have to set the timing light to double the figure to read the true advance. Cheers, Gavin :) youd have thought sprocket of all people would know that gav .
29th Mar, 2008 at 09:48:53pm
29th Mar, 2008 at 10:05:08pm
What filtering is being done?
29th Mar, 2008 at 11:14:43pm
answer is in here somewhere
30th Mar, 2008 at 10:21:03am
Some timing lights read double because they relate to each spark as 360 degrees of engine revolution. A wasted spark system fires twice every 360 degrees of engine revolutions (once every 180 degrees) so when the dial on timing light is set to 10 degrees it shows 20. I have a new-ish sealey timing light and it mainy shows correct timing with the odd quick reading at double, earlier sealeys show double so maybe the later ones have been modified! -MINI CLUBMAN 1380 TURBO- |
30th Mar, 2008 at 02:27:59pm
Gav covered it but heres another version
Edited by Turbo Tel on 30th Mar, 2008. website:- http://www.terryhunt.co.uk
31st Mar, 2008 at 10:56:19am
Thanks Gavin, thats what I was looking for, but a bit pricey! On 15th May, 2009 TurboDave said:
31st Mar, 2008 at 09:05:34pm
