Home > Help Needed / General Tech Chat > Light!!
Markie_D
Member #: 1660
Formally Mini_Uk
London
Lights *angry*
My front lights work, but not my side lights, which is why i orderd a new light switch. (not sure when thats going to arrive).
Anyway, when i turn the lights on to full, the dash light and the back lights dont come on. ive checked ruses etc.
could this problem to due to the switch ?
If not, what else should i check.
This is all i have left till it goes to MOT :)
Cant get me mate coz his busy :( wanker lol
Shit Happen's
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Switch or a bad earth somewhere.
On 19th Jan, 2010 wil_h said:
mlarj
Member #: 2397
Plymouth
Have you got access to a multi-meter? A quick switch check would be to measure the voltages. There should be a perm 12+ which is the supply to the lights, then when you put the switch to each position 12+ is applied to the other wires (side lights and main). You could use a bulb to test the switch if you are stuck.
When the sidelights are switched on, do you get any rear lights? if you get no lights it does tend to suggest a switch problem.
go for the switch as milaber says
neilj1678
Member #: 1297
Sunny Stockport
The sidelights run through a fuse but the headlights don't so it could be the fuse if your sidelights don't work. Dash lights are also fed from the sidelight circuit. I think it's one in the 4 way fuse block under the bonnet, have a look for a red wire with a green stripe (iirc).
You can also check the switch if you want by temporairly connecting the large brown wire and small red wire together at the back of the switch, if the lights come on it's a faulty switch.
My guess would be a dodgy connection in your fuse box though.
Theres a fuse in the fuse box that supplies power to the back lights and lights in the dash, i dont know if it does the side lights
i think its the second or third one down but i cant remember
Double check the fuses and the wires on the sides, mine used to fall off
Markie_D
Member #: 1660
Formally Mini_Uk
London
Well on that 4 way fuse block under the bonnet.
The 3rd fuse down wasn't connected right.
So now all works :) nice one :)
Cheers..
Shit Happen's
you have to rember though some minis were wired so permant live is not always like that mine is only with the ignition on :)
It's not a permanent live then! Your Mini has wonky wiring! *tongue*
jamesfawcett
Member #: 218
Bingley, West Yorkshire
check the wires in the front part of the front panel just above the grill on the inside, i bet its a rusty bullet connector or something!
