Home > Help Needed / General Tech Chat > Fuel pump
What do you think to this?
http://cgi.ebay.co.uk/MG-MAESTRO-MONTEGO-2...7QQcmdZViewItem
be fine, sytec stuff seems good.
Cheers Iain.
Mine has got rather loud. Still worked fine, but just noisy as hell.
just make sure its not come loose on the mountings.
mine went quiet when it failed, it jsut stopped! lol
you can get thoes from demontweeks for that sort of money as well
Sorry to bring this back up, but...
Would this one be any good?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?Vie...MEWA*tongue*IC&ih=019
Lets hope so as you've already won it! *laughing*
Carl S
Member #: 1761
Stalker
72.5 psi? Don't quote me but sounds like an injection pump at that pressure. Can the regulator cope?
Unless its meant to be 7.25!
Edited by Carl S on 8th Apr, 2008.
What's psi does the Metro turbo run?
Carl S
Member #: 1761
Stalker
not sure! Probably talking bollocks as usual :$
mg-metro-matt
Member #: 1870
Aldershot (we are top of the league, say we are...)
yeh that is just the max pressure, if you look at the sytec pump that has a max pressure of 7 bar, which off the top of my head is about 75psi, aslong as the pressure regulator is returning fuel to the tank then the fuel pressure will stay at 4psi above boost before or after the pressure regulator.
It is an injection pump afterall *wink*
The pressure it runs at on the car is controlled by the reg, put a 3bar reg on and you'll have 3bar fuel pressure.
Excellent, that's what I thought. Cheers guys.
