| Home > Help Needed / General Tech Chat > Inertia starter motor to pre-engaged, Wiring help!!! | |||||||
![]() 455 Posts Member #: 953 Senior Member London |
1st Apr, 2008 at 11:08:15pm
Hello,
34 Posts Member #: 1634 Member |
1st Apr, 2008 at 11:30:35pm
put the big cable from the battery onto the lug on the starter motor, then your small ignition wire from the key gos onto the smaller teminal on the starter, meaning there is always the battery supply connected and the ignition when the key is turned engeges the solenoid |
1st Apr, 2008 at 11:57:16pm
2nd Apr, 2008 at 12:02:04am
An easy way to do it is to move both thick wires currently going to the solenoid on the inner wing to the same terminal on the solenoid. This provides the main feed to the new starter and also means the loom is still being fed. Then all you need to do is disconnect the red/white wire from the inner wing solenoid, and extend this to reach the starter small terminal. Doing it this way means if you ever want to swap back to inertia starter its an easy job.
998 Posts Member #: 2178 Post Whore Leyland, Lancs |
2nd Apr, 2008 at 01:29:15am
On 2nd Apr, 2008 Tom Fenton said:
An easy way to do it is to move both thick wires currently going to the solenoid on the inner wing to the same terminal on the solenoid. This provides the main feed to the new starter and also means the loom is still being fed. Then all you need to do is disconnect the red/white wire from the inner wing solenoid, and extend this to reach the starter small terminal. Doing it this way means if you ever want to swap back to inertia starter its an easy job. Thats exactly how I've done mine and its been perfect. On 15th Jul, 2009 fastcarl said:
a breif struggle ensued but Will emerged the victor with a pair of undies in his possesion On 21st Sep, 2009 apbellamy said:
No, but you did chuck your guts up over my front gate the Saturday before! You even managed to get a bit in your arm pit... |
2nd Apr, 2008 at 03:00:15pm
Hi
2nd Apr, 2008 at 03:08:53pm
All the brown wires connect together, its the white/red that actually energises the solenoid or pre engagement
Edited by Turbo Tel on 2nd Apr, 2008. website:- http://www.terryhunt.co.uk
2nd Apr, 2008 at 03:47:04pm
Using the red/white wire to power the (pre-engaged) solenoid is a bad idea...
2nd Apr, 2008 at 05:41:48pm
On 2nd Apr, 2008 retired said:
Using the red/white wire to power the (pre-engaged) solenoid is a bad idea... The pre-engaged solenoid draws a lot more current than the original wing solenoid (because it is bigger as it has to move gears inside the starter motor). Thus the contacts inside the ignition barrel will overheat and eventually fail. Later Minis that had the pre-engaged starter had an additional relay that provided the feed to the pre-engaged solenoid so as not to overload the ignition switch barrel. Rod. Very good point Rod... So maybe mount a relay next to the old solenoid, use the brown wires for a supply to the contacts and the red/white to the relay coil to energise it. the output contact of the relay goes to the pre-engaged starter instead of the white/red In fact the solenoid is nothing but a big ass relay so you could even use that I suppose.. Terry Edited by Turbo Tel on 2nd Apr, 2008. website:- http://www.terryhunt.co.uk
2nd Apr, 2008 at 06:04:04pm
On 2nd Apr, 2008 Turbo Tel said:
In fact the solenoid is nothing but a big ass relay so you could even use that I suppose.. Terry Yes, The common "fix" (especially bearing in mind Tom's point about being able to revert easily to inertia) is to move the big cable from the starter motor side of the wing solenoid onto the top of the big cable from the battery - must be done this way around, don't move the battery cable to the starter motor post - leave everything else alone and simply run a reasonable size wire from the really big post that used to feed the starter motor, over to the pre-engaged solenoid large spade connector. You now have a 300A relay feeding the pre-engaged solenoid, 30A would be more than enough !!! (I think Leyland used a 20A relay). But it is simple and you can change back very easily and you won't overheat your ignition switch barrel. Rod. Schrödinger's cat - so which one am I ??? |
2nd Apr, 2008 at 06:26:28pm
It's also worth adding that for anyone who chooses to use the red/white to feed the bigger pre-engaged solenoid direct, if you have a ballast ignition system (using the additional tag on the wing solenoid, to provide the higher coil starting voltage) this would also need to be swapped to the auxiliary tag on the pre-engaged starter solenoid or you would have poor cold weather starting. Edited by Rod S on 2nd Apr, 2008. Schrödinger's cat - so which one am I ??? |
2nd Apr, 2008 at 07:18:22pm
An easy way to do it is to move both thick wires currently going to the solenoid on the inner wing to the same terminal on the solenoid. This provides the main feed to the new starter and also means the loom is still being fed. Then all you need to do is disconnect the red/white wire from the inner wing solenoid, and extend this to reach the starter small terminal. Doing it this way means if you ever want to swap back to inertia starter its an easy job. Hi, This is what I understand from what you say tom and most agree with me you so I think I will do it this way. * All Brown wires 1-2-3 fit on A. * 4- the cable from battery also fits to A. * Cable from B which looks the same type as the battery one,will now run from A to the starter, not B. * 5 which should be conneted to C, will now need to be extended to fit the soleniod to the starter. Is this right please ? No need for me to connet any other wires to the new starer apart from a big black cable and the small red/white wire ? Thanks again
2nd Apr, 2008 at 08:29:03pm
If you don't want to believe me, look at haynes (light blue) page 337 (and notes on page 338).
2nd Apr, 2008 at 09:11:03pm
Sorry Rod Im not to good at this wiring.
2nd Apr, 2008 at 10:24:51pm
3rd Apr, 2008 at 01:26:20am
On 2nd Apr, 2008 Bat said:
Hi, Connect 5 as it was, back on the solenoid. Then connect a thickish wire to B and run that to the large spade on the starter motor. The rest as you have it listed above
Cheers, Gavin :) I'm with Rod and Gav on this one, no reason to risk overloading the ign switch. so to sum up:-- 1,2,3,4 all go to terminal "A" a thick cable also runs from "A" to the big nut type terminal on the new starter, use the old cable that used to go to terminal B. You now run a cable from Terminal "B" to the big spade connector on the starter exactly as Gav said. When you turn the key:- red/white goes to 12v, this energises the solenoid and gives 12v to terminal B. This is exactly how it used to work on the old starter so no problem with the load on the ignition switch. Now the 12v from terminal B just energises the pre-engaged starter but the main power for the starter comes from terminal A i.e directly from the battery. Surely you have it now!! Edited by Turbo Tel on 3rd Apr, 2008. website:- http://www.terryhunt.co.uk
10th Apr, 2008 at 09:40:36pm
Cheers, Gavin :) I'm with Rod and Gav on this one, no reason to risk overloading the ign switch. so to sum up:-- 1,2,3,4 all go to terminal "A" a thick cable also runs from "A" to the big nut type terminal on the new starter, use the old cable that used to go to terminal B. You now run a cable from Terminal "B" to the big spade connector on the starter exactly as Gav said. When you turn the key:- red/white goes to 12v, this energises the solenoid and gives 12v to terminal B. This is exactly how it used to work on the old starter so no problem with the load on the ignition switch. Now the 12v from terminal B just energises the pre-engaged starter but the main power for the starter comes from terminal A i.e directly from the battery. Surely you have it now!! Hi Terry I fitted all the wires as you said and it didnt work !! So I then removed the red/white wire from the solenoid and placed it on to B and the engine turned over, the rest of the wires were all fitted the same way. What should I do ? Thanks for your help. |
10th Apr, 2008 at 10:10:13pm
11th Apr, 2008 at 02:47:58pm
Hi Gavin
11th Apr, 2008 at 03:33:17pm
At first it sounded like your wing solenoid isn't working....
11th Apr, 2008 at 04:12:22pm
Right, look at this. Schrödinger's cat - so which one am I ??? |
11th Apr, 2008 at 07:19:26pm
Hi Rod
11th Apr, 2008 at 08:03:32pm
Right,
12th Apr, 2008 at 12:07:35am
