Home > Help Needed / General Tech Chat > How low can I go?
I would like to go about 1/2 an inch lower, but then hit problems of the wheel hitting the arches over certain bumps.
Is there any way to get round this or are the standard wheel arches my enemy here. I reckon I may be able to nibble a bit more from the metal and plastic arches to stop rubbing on full lock.
How do the people with fingernail height clearences get round this problem?
This is as low as I can go at the moment.
Oh yeah, the wheels stick out from the arches by about an inch.
Edited by minimole23 on 3rd Apr, 2008.
G13B
Member #: 1376
fit a rear arb, then you can go lower without going superstiff dampers…
//marcus :$
What dampers have you got on there at the moment?
Mini_Andy
Member #: 432
Cut the metal away from under the arches, stiffen the shocks, and prepare for a bumpy ride!!!
spax adjustable jobbies
On about 8 out of 20 clicks I think rear
and 12 out of 20 front
That looks low enough, maybe too low at the back. If it was lower I think it would look wrong.
You would be better getting different arches as you can create an optical illusion making the car look lower.
jamesfawcett
Member #: 218
Bingley, West Yorkshire
8 clicks! wow, mine are on 4 clicks out of 30 and its still a stiff ride!
jamesfawcett
Member #: 218
there is petty much no rear suspension. I have learned to brace myself for spinal impact for certain bumps near home. It isn't helped by the cobra monaco seats eigher.
I did have it softer but it bottomed out. so it is the minimum I can get away with.
i reckon theres a bit more in there
not much, i think i used to stick 2 fingers in mine and they were a tight fit, phnarr!!
im sure the chinnor massive have run lower cars though
Jordan
Member #: 1392
Pointless Post Whore
Liverpool, North west
EWW
that is a sig if ever seen one!!!!
Indeed I believe they have, but after having to make my own exhaust ive raised it so the exhaust doesn't catch on speed bumps. *laughing*
I wonder if the standard arhes are my enemy, this photo shows more clearly how much the wheels protrude from the arch.
How do people stop them rubbing, or do you have no suspension? this is currently as low as I can go. I may lower it a touch and see
if it rubs again.
In fact I cracked the front plastic arch off the other day reversing up a slope on full lock, the tyre caught it from where the front was pushed down.
somewhere on here thers a thread with a load of peoples measurements ....er . no .nic ..!
It'll be this thread. *wink*
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=135452
Thats helpfull, I think I will stiffen the shocks a bit, not use full lock and lower it a fraction.
I have to say I really like the look of this car. I'd put a standard number plate lamp on and bin the fog light for one fitted in the rear lights, but otherwise perfect.
Any more photos?
did you cut the front wings?
it is a very nice specimen i have to agree
Nic, The front plastic arch and metal have been cut away as much as I can using the standard arch.
Heres a couple more of it. It just needs a propor engine now. the 1275 isn't fast enough.
steveobennet
Member #: 1657
wirral
snap! when i turned my rear shocks soft, and put some weight in the boot it bounced all over the place! its solid as a rock at the moment though i hate it when i haven't braced for bumps!
On 15th of Apr, 2007 at 09:08pm Vegard said:
What the fuck is that on the rear of the car? One of the most stupid things I've ever seen. Rest looks nice.
10.5 psi no idea how many banannas
i have 4.5 cooper 12's on the front of my mini and 6x12" minilights on the back the front is so low i cant get more than 1/2 lock before it scrubs :) love it but the back is pritty high, great for traction not so good on the twistys when its damp, i plan to have my project mini sitting like that low with the ashes but on 10's so i may get away with it, imo lower it more XD and invest in some rivets and a rivit gun *happy*
I'd raise the front up a bit and get some yokahama A048's on there, I haven't found the limits of mine yet on a dry public road.
I thought on 4.5 by 12's you would have a bit more steering. how is the gearbox casing looking with it that low*laughing*
i will take a picture 2moz, the last casing died on my mot lol and a speed bump or two or three... with my exhuast. the front just has nackerd suspension, but i cba to spend my money on it and it seemed to be fine arround combe, i run 165/60/12 a539's @32psi
