| Home > General Chat > Flywheel removal Problems | |||||||
11th Apr, 2008 at 09:48:25pm
I thought I'd swap the gearbox on the British Open this evening (I must find something better to do with my Friday nights) engine came out nice and easily but I couldn't get the blooming flywheel off to save my life, when it eventually cam off this is what I found:
![]() 6752 Posts Member #: 828 Post Whore uranus |
11th Apr, 2008 at 10:00:24pm
was that with a stock flywheel rob ? Medusa + injection = too much torque for the dyno ..https://youtu.be/qg5o0_tJxYM |
11th Apr, 2008 at 10:00:26pm
Flywheel 180 degrees out when pulling ???
11th Apr, 2008 at 10:27:03pm
Stock flywheel.
![]() 6965 Posts Member #: 507 Fastest A Series Mini in the World leeds/wakefield. |
11th Apr, 2008 at 10:34:55pm
On 11th Apr, 2008 retired said:
Flywheel 180 degrees out when pulling ??? ie, C washer was "upside down" ??? never understood the 180 degs our C clip , what difference does it make, none as far as i am concerned. i certainly dont put the clip in with no 1 at tdc, , it goes in whichever way it goes at the time, ive seen slightly worc C clips but nothing like that, its a thrusting side thing for sure, was it excessively high miles. edit, has the f/wheel fretted at all, carl Edited by fastcarl on 11th Apr, 2008. |
11th Apr, 2008 at 11:59:18pm
12th Apr, 2008 at 06:38:51am
On 11th Apr, 2008 fastcarl said:
never understood the 180 degs our C clip , what difference does it make, Depends how you take the flywheel off - if you remove the clutch diaphragm spring assembly first so your are just pulling the flywheel and leaving the driven plate and pressure plate behind hanging on the primary gear, then yes, it would "normally" make no difference - it woud probably just fall to the floor if it's upside down. If your pulling the whole lot together (which is how the manual says to do it) with the thrust bearing plate removed and the puller bolts fitted through the 3 holes in the diaphragm plate (diaphragm spring on a verto) provided for just that purpose, then, if upside down, it will drop into the gap between the flywheel and driven plate as everything moves forward and will be bent as pulling continues. For that reason, I always dismantle the clutch first in case someone before me has put it in the wrong way up. However, even then, on the later flywheels, there is an additional groove machined into their boss just behind where the C clip sits which it can drop into and get caught anyway. So having it the right way up is good practice. Schrödinger's cat - so which one am I ??? |
![]() 3184 Posts Member #: 628 Post Whore a LIL fishing village on the coast - Newcastle Upon Tyne |
12th Apr, 2008 at 09:26:00am
bloody hell thats well mangled, i never seen anything like that before
On 17th Aug, 2009 Jay#2 said:
I doubt I'll be dipping into the 13's like you did though! |
![]() 3756 Posts Member #: 1709 I like granny porn. LONDONSHIRE |
12th Apr, 2008 at 09:31:23am
interesting... On 2nd Oct, 2009 Vegard said:
I bet my first wank came quicker than your first mini turbo These new modern turbos with their quick spool up time, would make the competition harder. On 15th Aug, 2011 robert said:
phew!!! thank you brett for smashing in my back doors .( not something i imagined writing... EVER) |
12th Apr, 2008 at 10:34:47am
Yes I'm with that carl as your pulling aways from the clip and it's free to move over it as it likes, it's only whn putting f wheel on does it help to st up at the right 180 degrees so you don't bend it then, if it moves. Best 1/4 mile 13.2 seconds @116 mph
12th Apr, 2008 at 11:26:35am
With the 180 out c clip thing,
12th Apr, 2008 at 11:45:23am
Pre-verto if you pull the flywheel and clutch together (as per the manual). Same happens on a Verto Schrödinger's cat - so which one am I ??? |
12th Apr, 2008 at 11:48:37am
Nice work retired, that's clear to see. So a standard flywheel can bend it then, An after market one that most people seem to use doesn't have this groove, so would be ok. Best 1/4 mile 13.2 seconds @116 mph
12th Apr, 2008 at 12:16:18pm
Nowhere near your photographic abilities !!!!
12th Apr, 2008 at 12:19:00pm
Good stuff!
