| Home > Help Needed / General Tech Chat > turbo carb for n/a | |||||||
298 Posts Member #: 1357 Senior Member telford,shropshire |
17th Apr, 2008 at 06:14:11pm
hey chaps did a quick search but could find anything on this, so is it possible to run the turbo carb on a n/a lump? if so which would be the fuel return pipe from the carb?
'always keep a spare shot for a stray bird' |
17th Apr, 2008 at 07:06:49pm
Yes, off boost all turbo cars are effectively naturally aspirated. Isambard Kingdom Brunel said:
17th Apr, 2008 at 07:10:10pm
great but which would be the fuel return from the carb? is it the one next to the fuel in? 'always keep a spare shot for a stray bird' |
17th Apr, 2008 at 07:45:34pm
the fuel return is on the regulator, not the carb |
17th Apr, 2008 at 07:45:42pm
fuel return is from the pressure regulator if im not mistaken not the carb Drives
17th Apr, 2008 at 08:35:34pm
i thought that because the reg works off the pressure from the plenum, that i would not be able to use it? is it just a case of opening up the adjuster on the regulator then? 'always keep a spare shot for a stray bird' |
17th Apr, 2008 at 10:08:09pm
17th Apr, 2008 at 10:52:11pm
thats it, there is no boost so the regulator wont add any extra fuel pressure. you can just block the boost reference pipe from the regulator off. i've done it on a few occassions where i had to run NA due to turbo issues etc |
18th Apr, 2008 at 11:48:34am
thanks chaps, big help. 'always keep a spare shot for a stray bird' |
36 Posts Member #: 4335 Member Hull / Scunthorpe |
7th Dec, 2008 at 01:48:08pm
hijacked lol, can u run a turbo carb on an n/a engine, without a fuel pump/regulator?
7th Dec, 2008 at 01:49:45pm
depends what pressure your fuel pump gives, na carbs like 3 or so psi... "Turbo's make torque, and torque makes fun"
7th Dec, 2008 at 02:01:16pm
It'll be the standard 1275 (mg metro) mech pump. For now, doing a conversion, but my hif44 needs a rebuild, so got a turbo 1 ready for the conversion, and would like to use it. Anything special need doing to the extra hose holes? (excuss my dumbness) |
7th Dec, 2008 at 05:21:45pm
sniff?
7th Dec, 2008 at 06:36:34pm
wang it on and it'll be fine On 20th Oct, 2015 Tom Fenton said:
7th Dec, 2008 at 06:58:37pm
LoL, gulps I suppose! |
7th Dec, 2008 at 07:07:36pm
dont forget that a turbo engine thats not on boost is an n/a engine so it will work fine on yours On 20th Oct, 2015 Tom Fenton said:
8th Dec, 2008 at 07:14:09pm
I guessed as much, Im just a little dumbed by the connections. I mean theres LOADS of FQA pics showing them on a turbo setup. But nil showing how to plumb up on an NA setup (without FPreg) I would ask for a graph, but look what happend last time LMAO |
8th Dec, 2008 at 07:37:16pm
just plumb it the same as a turbo carb, the FPR is connected to the plenum.
![]() 667 Posts Member #: 5232 Post Whore basingstoke |
7th May, 2010 at 04:55:38pm
Massive bump!
Mr. Prawn, the friendly Crustacean- slowly making steps towards forced induction. |
7th May, 2010 at 06:26:46pm
On 7th May, 2010 Prawn said:
Massive bump! glad I found this, I'm sick of my webber, and it making far too much noise compared to the gains it see's over the old hif44, so I'm ditching the 45 and sticking on my new turbo carb, I don't fancy driving all the way to the ring again in september with the webber! your driving to nurburg in september? i am too! is there a mini event on? AND if your running the turbo carb NA dont forget to change the needle to a non turbo one cause it will over fuel mid/high rpm? |
