Home > Help Needed / General Tech Chat > Megajolt Formula
colas
Member #: 102
Pennsylvania USA
Hi
Does anyone know what the formula needs to be in excel to convert the load into PSI that comes from the Megajolt when you do a datalog.
Thanks
colas
14.7 psi is 1 bar or 100 kpa.
Remember anything below 100 kpa on a MAP sensor is a vacuum, so 200 kpa will be 14.7 psi of boost.
I'm guessing the scale is in kpa?
Ben H
Member #: 184
Melton Mowbray, Pie Country
1 bar = 14.5 psi
http://www.twin-turbo.co.uk
Close *surprised*
I always thought 1 bar was 14.7psi too.......
evolotion
Member #: 83
Glasgow, Scotland
so did i .. its a conspiracy.
Denis O'Brien.
evolotion
Member #: 83
Glasgow, Scotland
a hah. 14.7 psi is one atmosphere.
1 atm = 760 torr = 14.7 psi.
Bar
(bar) The bar nearly identical to the atmosphere unit.
One bar = 750.062 torr = 0.9869 atm = 100,000 Pa.
there you go :)
Denis O'Brien.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Evo is correct.
1 atm is a average of the pressures we all expereince, as you know they change regularly!
Alex
AlexF
Ben H
Member #: 184
So in our own way we are both correct. I don't thing 0.2 is going to make much of a difference anyway, not if reading my boost gauge is anything to go by.
So we're all correct, but we've still not answered the question!
So ... multiply the number from MJ by 0.1450377 to get psi :)
colas
Member #: 102
Pennsylvania USA
Thanks guys
